HTTPS Probe on ACE
jason.williams
Level 3
Level 3
We have some webserver behind our ACE that use SSL certificates that are issued by an internal CA.
Do I need to do anything special in order to probe HTTPS?  Does the ACE need the internal CA to be trusted?
Thanks.
Jason
kitanaka
Level 5
Level 5
If https server is working properly, only you need to do is configure https probe on ACE like below.
You do not have to anything related certificate on ACE side.
ACE-A327/context02# show running-config
Generating configuration....
probe https HTTPS
  interval 15
  passdetect interval 60
  ssl version all
  expect status 200 200
  open 1
rserver host S1
  ip address 10.1.142.209
  inservice
serverfarm host SF
  probe HTTPS
  rserver S1
    inservice
interface vlan 11
  ip address 10.1.142.1 255.255.255.0
  no shutdown
ACE-A327/context02# show probe detail
probe       : HTTPS
type        : HTTPS
state       : ACTIVE
description :
   port      : 443     address     : 0.0.0.0         addr type  : -
   interval  : 15      pass intvl  : 60              pass count : 3
   fail count: 3       recv timeout: 10
   SSL version      : All
   SSL cipher       : RSA_ANY
   http method      : GET
   http url         : /
   conn termination : GRACEFUL
   expect offset    : 0         , open timeout     : 1
   regex cache-len  : 0
   expect regex     : -
   send data        : -
                ------------------ probe results ------------------
   associations ip-address      port  porttype probes   failed   passed   health
   serverfarm  : SF
     real      : S1[0]
                10.1.142.209    443   DEFAULT  11       0        11       SUCCES
S
   Socket state        : CLOSED
   No. Passed states   : 0         No. Failed states : 0
   No. Probes skipped  : 0         Last status code  : 200
   No. Out of Sockets  : 0         No. Internal error: 0
   Last disconnect err :  -
   Last probe time     : Thu Apr 14 17:34:02 2011
   Last fail time      : Thu Apr 14 17:30:42 2011
   Last active time    : Thu Apr 14 17:30:44 2011
ACE-A327/context02#
Additionaly, you can specify cipher in client hello, also you can select ssl/tls version.
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/vA2_3_0/configuration/slb/guide/probe.html#wp1162289
If you find this helpful, please rate this topic.
Kim.
