HTTPS TO HTTPS rewrite error with Wilcard Cert
cbregeripr
Community Member
I have a wildcard cert installed on my ACE and a HTTP redirect for any http traffic.  The redirect works fine for all http traffic and HTTPS traffic.  I am recieving an error when users try to connect to https://domain.com.  If they connect to Https://www.domain.com, https://mail.domain.com, etc. it works fine.  I only get errors when the www or any specific host name is left off and https request.  I am receiving the error the domain does not mach the cert.  The cert is configured for *.domian.com.  Below is my config.  Any Ideas?
rserver redirect HTTPS-REDIR
  webhost-redirection https://%h%p 301
  inservice
rserver redirect HTTPS-REDIR-domain
  webhost-redirection https://www.domain.com 301
  inservice
rserver host WEBSERVER-01
  ip address 10.50.20.132
  inservice
rserver host WEBSERVER-02
  ip address 10.50.20.133
  inservice
action-list type modify http ADD-HTTPS
  ssl url rewrite location ".*"
serverfarm host ALGINE-SERVERFARM-80
  probe PING
  fail-on-all
  rserver WEBSERVER-01 80
    inservice
  rserver WEBSERVER-02 80
    inservice
serverfarm redirect HTTP-HTTPS-REDIR
  description Redirection from Port 80 to 443
  rserver HTTPS-REDIR-domain
    inservice
ssl-proxy service domain-domain-COM
  key *.domain.com-KEY-2011
  cert *-domain-com.cer
  chaingroup TEST-CHAIN
  ssl advanced-options PARAM-RSA-SSL1
sticky http-cookie ALG-LB ALG-COOKIE-01
  cookie insert
  timeout 120
  replicate sticky
  serverfarm DOMAIN-SERVERFARM-80
class-map match-any CM-domain-COM-http
  2 match virtual-address 11.11.11.11 tcp eq www
class-map match-any CM-domain-COM-https
  2 match virtual-address 11.11.11.11 tcp eq https
class-map match-any CM-TEST-MAP
class-map type management match-any remote_access
  2 match protocol xml-https any
  3 match protocol icmp any
  4 match protocol telnet any
  5 match protocol ssh any
  6 match protocol http any
  7 match protocol https any
  8 match protocol snmp any
policy-map type management first-match remote_mgmt_allow_policy
  class remote_access
    permit
policy-map type loadbalance first-match CM-domain-COM
  class class-default
    sticky-serverfarm ALG-COOKIE-01
policy-map type loadbalance first-match CM-domain-COM-http
  class class-default
    serverfarm HTTP-HTTPS-REDIR
policy-map multi-match INT-VLAN229-VIPS
  class CM-domain-COM-http
    loadbalance vip inservice
    loadbalance policy CM-domain-COM-http
    loadbalance vip icmp-reply active
    appl-parameter http advanced-options HTTP-OPTIONS_1
    connection advanced-options TCP-CONN-OPTIONS
  class CM-domain-COM-https
    ssl-proxy server domain-domain-COM
Borys Berlog
Hi Chris
ACE can't cause such type of problems, as this check is a simple check done on browser side.
The problem seems to be that wilcard certificate for *.domain.net matchs e.g. these domains : a.domain.net, b.domain.net, c.domain.net but doesn't match domain.net
http://wiki.cacert.org/WildcardCertificates
