inbound packet loss TCP SYNs
paul.matthews
Level 5
Level 5
You'll be fed up of me soon!
I have a CSS 11800 running ap0500063 (old I know but there are political reasons making an upgrade awkward) that seems to ignore some TCP SYNs for no apparent reason.
The symptoms are that occasionally part of a website (odd that it is normally one of 2 images) fails to display.
Looking at a sniffer trace (I only have one near the client, it has been reported to be seen adjacent to the CSS) where I can see traffic going backwards and forwards, but one SYN is ignored, even when it is retried. The llama debug set to:
flow trace-ip 80.40.30.182 (client IP)
flow options 0x00000131
(advice from http://www.cisco.com/en/US/products/hw/contnetw/ps789/products_tech_note09186a0080094ebf.shtml)
shows no sign of the inbound syn.
It just seems to be syns that get ignored...
Any thoughts?
Gilles Dufour
Paul,
would be good to know what type of content rule you are using as it makes a big difference.
About flow trace-ip on the 11800, do you see the other syn's ? or nothing at all ?
Gilles.
The sanitised version of the rule is below.
I am pretty sure I saw other SYNS, but as I was seeing other traffic on the connection, I was not specially looking for the SYNs.
content
protocol tcp
port 80
url "//www..info/*"
no persistent
add service serv01_http
add service serv02_http
balance aca
vip address 172.19.111.56
active
Paul,
this is standard config.
A L5 rule, so the SYN should be answered by the CSS itself and you should see it with the flow trace-ip command.
Unfortunately, there is no bug clearly matching your problem.
Do you see any error messages in the log ?
All I could recommend is an upgrade to 6.10 to get the new queueing system to will solve a lot of unecessary packet drops.
Gilles.
No messages in the log. I have started the political side of things to perform thr upgrade...
Thanks for the help.
