Incorrect SNMP readings when monitoring the temperature of a Cisco 3850 via PRTG
alexmccaskie
Hello
I have recently installed a new Cisco 3850 which is using IOS 3.3.4.  I am monitoring monitoring SNMP using PRTG which is giving the following error:
19 C (temperature 2006 (switch 2 - Temp 0 GREEN)) is above the error limit of 0 C.
I have read case  CSCun78227 which states that the issue has been resolved by IOS 3.3.4 but as you can see from the error message above, I am still experiencing this issue and I have seen similar experiences on forums.
Can anybody please clarify if this bug still exists with IOS 3.3.4.
Thanks in advance.
0 Replies 0
