inline network card issue
malcolm sydney
Community Member
hi all
Please help with the issue below
I have connected the branch WAE inline to a Nortel Router(Cross cable) and Nortel 8600 Switch(Straight cable) inlineGroup 1/0. I get the following below with the Lan interface on the group administratively shut. I have tried different combinations of cables as well.
interface InlineGroup 1/0
inline vlan all
exit
from sho int inlinegroup 1/0
Interface is in bypass operating mode.
Standard NIC mode is on.
Disable bypass mode is on.
VLAN IDs configured for inline interception: All
Watchdog timer is disabled.
Inline Port Statistics Of The Group:
WAN Port :
Device name        : eth4. Bypass master interface.
Packets Received   : 0
Packets Intercepted: 0
Packets Bridged    : 0
Packets Forwarded  : 0
Packets Dropped    : 0
Packets Received on native      : 0
Active flows for this interface : 0
Ethernet Driver Status
Type:Ethernet
Ethernet address:00:E0:ED:0C:6A:0A
Maximum Transfer Unit Size:1500
Metric:1
Packets Received: 0
Input Errors: 0
Input Packets Dropped: 0
Input Packets Overruns: 0
Input Packets Frames: 0
Packet Sent: 0
Output Errors: 0
Output Packets Dropped: 0
Output Packets Overruns: 0
Output Packets Carrier: 0
Output Queue Length:1000
Collisions: 0
Base address:0x6080
Flags:UP BROADCAST MULTICAST
Link State: Interface is up,line protocol down
Jan Rockstedt
Level 6
Level 6
Can send an:
sh int inlineport 1/0/lan and a sh int inlineport 1/0/wan
Is the router and the switch in automode?
Jan
malcolm sydney
Community Member
hi Jan
Please see below. I am running version 4.3.3. no lights are flashing on the card.
Thanks in advance
LAN
Device name        : eth5. Bypass slave interface.
Packets Bridged    : 0
Packets Dropped    : 0
Type:Ethernet
Ethernet address:00:E0:ED:0C:6A:0B
Metric:1
Packets Received: 0
Input Errors: 0
Packet Sent: 0
Output Errors: 0
Collisions: 0
Base address:0x60c0
Flags:BROADCAST MULTICAST
Link State: Interface is administratively down, line protocol down
Mode: autoselect
WAN
Packets Bridged    : 0
Packets Dropped    : 0
Type:Ethernet
Metric:1
Packets Received: 0
Input Errors: 0
Packet Sent: 0
Output Errors: 0
Collisions: 0
Base address:0x6080
Mode: autoselect
device was faulty and had to be replaced
