Invalid packets dropped by WAE
Our WCM is reporting 'SIA invalid packets are detected in service-node' on one of our WAEs (8541).
This alarm appears in WCM for few minutes and then vanishes. When I check alarm's description on WCM it says the following:
Details: The System Monitor indicates that invalid SIA packets are seen in service-node.
Action: Execute show statistics service-insertion data-path to verify the service-node SIA packet statistics. There can be a network issue involved.
However, when I execute 'show statistics service-insertion data-path' command, I see that amount of 'Number of packets with invalid socket buffer' is increasing, not SIA related counters. Also, what's SIA for WAAS? It is not EIGRP's SIA, isn't it?
Number of invalid packets dropped :                        24
  Number of packets with invalid IP :                      0
  Number of packets with invalid SMC type :                0
  Number of packets with invalid SMC version :             0
  Number of packets with invalid SWIRE header :            0
  Number of packets with invalid SIA opcode :              0
  Number of packets with invalid IP checksum :             0
  Number of packets with invalid socket buffer :           24
  Number of packets with invalid IP header :               0
Can't find any information about it. What does 'invalid socket buffer' means from WAAS perspective?
Is there anyone to quickly comment on this or do I have to go back to TAC with this question?
Tim
adrian.falbo
I see the same exact issue.
Found no solution yet. Have you tried reloading? Did it work?
Number of packets received: 388164861
Number of invalid packets dropped : 388164861
Number of packets with invalid socket buffer : 388164861
Hello. I haven't tried to reboot, but this appliance was rebooted not long time ago - after downgrade to 5.5.7 from buggy 6.2.3a. I don't think a reboot will help in this case.
What I hate is lack of any information on these type of errors... I will try to raise this with Cisco next week when I am back to the office.
