IOS SLB Products
jason.linden
Community Member
I have recently been researching the IOS SLB features but have had a hard time finding the list of products that support IOS SLB and which feature sets it is available in. Does anyone have the CCO link where this is all located? Thanks!!
-jason
mmellet
Level 7
Level 7
SLB is listed on feature navigator at www.cisco.com/go/fn and shows 12.1(9)E, 12.1(9)E2, 12.1(9)E1, 12.1(10)E, 12.1(10)E5, 12.1(10)E3, 12.1(10)E2, 12.1(10)E1.
perherna
This feature can be run on the 7100 & 7200 series routers and on the Catlyst 6000 series switches equipped with a Superviser 1 or 2 routing blade.
It will also run on 4840g switches which are currently end-of-sale.
You'll have to use the feature navigator to make sure which software image you need for which platform.
Cheers,
Perry.
