Is configuring PCKS12 cert different than PEM?
nygenxny123
I have been uploading PEM certs for some time with no issue...using the following basic config
ssl-proxy service CERT
  key mykey.pem
  cert mycertt.pem
However I just uploaded a pcsk12 file and it appeared to upload fine
under
#sh crypto file
myfirstpcsk12.pcsk12              4998  PKCS12  Yes        BOTH
ssl-proxy service MYFIRSTPCSK
  cert myfirstpcsk12.pcsk12
under class
class customer-vip
    loadbalance vip inservice
    loadbalance policy customer -l7slb
    loadbalance vip icmp-reply active
    nat dynamic 1 vlan 44
However when I try to associate the class w/ the proxy server i get the following error
(config)# policy-map multi-match VIP
(config-pmap)# class customer-vip
(config-pmap-c)# ssl-proxy server MYFIRSTPCSK
Error: ssl-proxy doesn't have a valid key/cert, cannot use it.
I'm not sure why im getting that error..
the sho crypto file output appears finfe
Daniel Arrondo Ostiz
When using PKCS12 certificates, you need to configure the same file name for both cert and key under the ssl-proxy. Can you please give it a try?
I hope this helps
Daniel
I hope this helps
Daniel
that was it..
thx!
