Is possible to connect to more than one core WAE from edge?
jxarzaolano
I am trying to find in the documentation, but it is being hard to solve, if it is possible to connect simultaneously to more than one Core-WAE from a Edge-WAE
Daniel Laden
Level 4
Level 4
With the release of 4.1, the concept of core and edge becomes less of a concern. All devices are edge and acceleration is between any edge device.
The WAE is looking for the present of TCP option 21. If found, the WAE knows there is a peer WAE it can accelerate with.
-Dan
Thanks Dan!
