Is there a way to direct requests based on HTTP return-code checking?
qixie
Community Member
I'd like to implement a policy based on return-code. The algorithm is as below,
If HTTP return-code == 500 to 600
serverfarm1
else
serverfarm2
We have a CSM V3.2. Can someone tell me if this is doable? If yes, would you please tell me how.
Appreciation, Q.Xie
Gilles Dufour
it is feasible in 2 steps.
1- create an HTTP probe that will check the server status and if the response is between 500-600 mark the server as down.
2- use a backupserverfarm to use when all servers from the main serverfarm are down.
There is no way to redirect a connection based on the server response.
Gilles.
Thanks for rating this answer.
Gilles, Thanks for your help.
I might not explain clearly what I wanted. We want to do the failover per application not the whole server site. For example, if an application on San Jose down, I'd like to re-direct this particular application to RTP's servers, if its return code is 500-600. The method you recommended will bring the whole server down and switch to backup servers which is not what we want. Hope it's clear this time. Please help!
Thx,Q.Xie
The solution I suggested is still what I recommend.
What you have to do is split your serverfarm in multiples instances. One for HTTP and another one for the rest of your applications. Or you could do one for each application.
The serverfarm for HTTP will have the HTTP probe and will go down when the response is 500-600.
The other serverfarm(s) will not use the same HTTP probe and should not go down based on the response code.
ie:
serverfarm WEB
real 10.10.10.10
ins
real 20.20.20.20
ins
probe http
serverm ALL
real 10.10.10.10
ins
real 20.20.20.20
ins
no probe
vserver web
vip 1.1.1.1 tcp 80
serverfarm WEB backup WEB_B
vserver all
vip 1.1.1.1 any
serverfarm ALL
Hope this helps.
Gilles.
Gilles, Thx a lot.
Your suggestion probably works. I will test it and let you know.
Q.Xie
