ISR-WAAS and AppNav
hounshamp
Hi all
Situation is this. I have 2 x 4351-AX routers with the SSD and memory upgrades etc. One will terminate MPLS and the other internet DMVPN or similar and both with have ISR-WAAS configured.
Is there an argument to have these configured a standalone WAAS devices or should they be in an AppNav cluster? Are there any pros and cons to either method here?
Also if running Akamai Connect on just the internet facing device, does this mean it should not be part of an AppNav cluster?
Many thanks in advance.
Dev Vishwakarma
You should have the ISR-WAAS configured part of AppNav cluster. You can not have WCCP interception on the ISR-WAAS only Appnav.
WAAS newer codes can work with Akamai connect.
http://www.cisco.com/c/en/us/solutions/collateral/enterprise-networks/intelligent-wan-akamai/q-and-a-c67-731480.html
http://www.cisco.com/c/en/us/td/docs/app_ntwk_services/waas/waas/v551/note/waas551xrn.html#pgfId-90802
Dev Vishwakarma
