issue while accessing links on portal
Are there any special configuration steps to be taken in ACE configuration when we redirect users depending on url values?
we have our main website https://abc.com and it provides links to users for various applications.
If i go to https://abc.com and click the link xyz on it, i get back to main page again and current connections drops to 0. here my browser should be redirected to https://abc.com/xyz which is not happening.
But if i type in https://abc.com/xyz in browser, i go to correct page.
below is my configuration. please let me know if any other configuration is needed, Below config is with 2 links but actual production has many links.
I have similar issue for another application where links on main page can not be accessed. that application works on http  instead of https.
rserver redirect xyz
  inservice
  webhost-redirection "https://abc.com/xyz"
rserver redirect uvw
  inservice
  webhost-redirection "https://abc.com/uvw"
rserver host abc
ip address 1.1.1.1
inservice
serverfarm redirect xyz
rserver xyz
inservice
parameter-map type http case_param
  case-insensitive
  no persistence-rebalance
  set header-maxparse-length 65535
  set content-maxparse-length 65535
  length-exceed continue
parameter-map type ssl abc
  cipher RSA_WITH_3DES_EDE_CBC_SHA
ssl-proxy service abc
  key abc
  cert abc
  ssl advanced-options abc
serverfarm redirect uvw
rserver uvw
inservice
serverfarm host abc
rserver abc
inservice
class-map type http loadbalance match-any map1
   match http url "/xyz"
   match http url "/uvw"
policy-map type loadbalance first-match ssl-abc
class map1
    serverfarm xyz
class map2
    serverfarm uvw
class class-default
    serverfarm abc
class ssl-intranet
    loadbalance vip inservice
    loadbalance policy ssl-abc
    loadbalance vip icmp-reply active
    nat dynamic 1 vlan 368
    appl-parameter http advanced-options case_param
    ssl-proxy server abc
Cesar Roque
Level 4
Level 4
HI,
Try enabling persistence-rebalance, the parameter should look like this:
  case-insensitive
Cesar R
ANS Team
--------------------- Cesar R ANS Team
