Issue with ACE Module URL match policy...
cjkozloski
Need a little help here if possible.
I have a set of URL's that I am trying to get a policy match to work on. Basically, I have 3 url's that I want to use one server farm and a catch-all url that gets redirected to another serverfarm. Here's what it looks like:
SERVERFARM A:
/token-generator/
/regulatory-services/
/developers/
SERVERFARM B:
dev.url.com
The catch-all url in serverfarm b is working just fine. However, I keep seeing page cannot be displayed for the other url's even though when I go to the backend server url's they show up just fine. I can't figure out where this is failing. Here is my config for this setup:
rserver host XXX_DEV_AFAFG-PD-NWEB02
  ip address 3.3.3.3
   inservice
exit
rserver host XXX_ROGUE
  ip address 2.2.2.2
   inservice
exit
serverfarm host XXX_DEV_AFCORP
  rserver XXX_DEV_NWEB02
   inservice
  exit
exit
serverfarm host XXX_ROGUE_REDIRECT
  rserver XXX_ROGUE
   inservice
  exit
exit
class-map type vip loadbalance match-any L7_CLASS_VIP_XXX_DEV
  10 match virtual-address 1.1.1.1 tcp eq www
exit
class-map type http loadbalance match-any L7_CLASS_URL_XXX_DEV
  10 match http url /token-generator.*
  20 match http url /regulatory-services.*
  30 match http url /developers.*
exit
class-map type http loadbalance match-any L7_CLASS_ROGUE_XXX_DEV
  10 match http url .*
exit
policy-map type loadbalance first-match XXX_DEV_HTTP
description XXX policy map
class L7_CLASS_URL_AFPRO_DEV
  serverfarm XXX_DEV_AFCORP
exit
class L7_CLASS_ROGUE_AFPRO_DEV
  serverfarm XXX_ROGUE_REDIRECT
exit
exit
policy-map multi-match VIPS
class L7_CLASS_VIP_XXX_DEV
  loadbalance vip inservice
  loadbalance policy XXX_DEV_HTTP
  loadbalance vip icmp-reply
  nat dynamic 1 vlan XXX
  appl-parameter http advanced-options HTTP-PERSISTENCE
exit
exit
wr mem
Any help with this would be appreciated. Thanks.
ajayku2
Hi Christopher,
You have created Class "L7_CLASS_URL_XXX_DEV" but you are not using it anywhere.
So ideally it should be like this :
class L7_CLASS_URL_XXX_DEV
   SERVERFARM A
You can accomodate rest of the config accordingly.
hope that helps.
regards,
Ajay Kumar
ajayku2
Hi Christopher,
   SERVERFARM A
hope that helps.
regards,
Ajay Kumar
Thanks for the reply. You are correct. Although that was not the resolution to the answer you did find something that I needed to fix. Thanks for that.
It turns out that the servers on the back end had strict naming enabled which was causing it to fail.
Thanks for the help.
Hi Christopher,
Thanks for the feedback. Good to hear that the issue is resolved.
regards,
Ajay Kumar
