issue with cookie based stickiness
arulnambis
Community Member
Dears,
We have ACE 4710, It is configured with IP based stickiness and working fine for a web application server (BMC Remedy). We tried configuring cookie based stickiness for the same server. Server application is having JSESSIONID.
But after configuring cookie based stickiness, there is an issue that the first page is coming for entering login credentials and after entering it the page is blank or not responding.
What is the pre-requirement for configuring cookie based stickiness in ACE for BMC Remedy web application and which type of cookie based stickiness is suitable or possible?
Req. your suggestions and please post in case of any additional information required on this. Thanks in advance.
8 Replies 8
sivaksiv
We need the full config and sniffer capture to verify this.
Siva
Hi Siva,
Thanks for your feedback.
But we are getting empty logs from Wireshark while capturing for Application server Virtual IP address. Any suggestion?
Will Wireshark not work for VIP !!???
Thanks & Regards,
You can take a capture on ACE itself to verify. If not you need to span both the client and server vlan to capture the traffic.
If its a valid capture you should be able to see all the packets in wireshark,
ACE capture:
http://docwiki.cisco.com/wiki/Cisco_Application_Control_Engine_(ACE)_Troubleshooting_Guide_--_Overview_of_ACE_Troubleshooting#Capturing_Packets_in_Real_Time
Siva
Jorge Bejarano
Level 10
Level 10
Can you include your current configuration?
It might be possible you need a http parameter.
Jorge
Hi Jorge,
Now ACE is running with IP based stickiness. However the below are the configuration we tried for cookie stickiness.
Please suggest and let me know if you require any additional clarification . Thanks.
rserver host Remedy-Prod1
  description RemedyProd-Primary-Server
  ip address 10.132.11.21
  inservice
rserver host Remedy-Prod2
  description RemedyProd-Secondary-Server
  ip address 10.132.11.22
  inservice
serverfarm host SF_Remedy-Prod
  probe HTTP_probe1
  probe ICMP_probe
  rserver Remedy-Prod1
    conn-limit max 4000000 min 4000000
    inservice
  rserver Remedy-Prod1 80
    inservice
  rserver Remedy-Prod2
    inservice
  rserver Remedy-Prod2 80
    inservice
sticky http-cookie JSESSIONID Remedy-PROD-COOKIE
  serverfarm SF_Remedy-Prod
timeout 720
timeout activeconns
class-map match-any Remedy-Prod-VIP
  3 match virtual-address 10.132.11.51 tcp eq https
policy-map type management first-match remote_mgmt_allow_policy
  class remote_access
    permit
policy-map type loadbalance first-match slb-Remedy-Prod
  class class-default
    sticky-serverfarm Remedy-PROD-COOKIE
policy-map multi-match VIP_Access
class Remedy-Prod-VIP
    loadbalance vip inservice
    loadbalance policy slb-Remedy-Prod
    loadbalance vip icmp-reply
    nat dynamic 5 vlan 11
Can you remove the timeout and put "cookie insert browser-expire".
Also change the name of the sticky groupe (not "JSESSIONID"; put something else; there is probably a conflict with an existing JSESSIONID cookie)
Does it change something ?
Hi Surya,
Thanks for your suggestion...
Already we tried with cookie insert browser-expire option also but not working.
We will try once again as per your suggestion and will share the feedback. I believe stick group name mentioned as Remedy-PROD-COOKIE in my configuration.
Thanks.
Jorge Bejarano
Level 10
Level 10
Hi Arulnambi,
Can you try this perhaps?
parameter-map type http PARAMETER-HTTP
  case-insensitive
  persistence-rebalance
  set header-maxparse-length 65535
  set content-maxparse-length 65535
  length-exceed continue
  parsing non-strict
    appl-parameter http advanced-options PARAMETER-HTTP ---> apply it like this
Jorge
