CSM FT setting
fabio.marino
Level 5
Level 5
I need to discovery  members of a FT group set in a CSM LB.
I am on the Swicth_1 that is the standby and now I want to figure out which switch  is the primary.
Is there any useful command?
Thanks.
Jorge Bejarano
Level 10
Level 10
Cat6k-2# show module csm 4 ft
FT group 2, vlan 30
 This box is active
 priority 10, heartbeat 1, failover 3, preemption is off
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/csm/3.2/command/reference/s.html#wpxref93908
Jorge
Kanwaljeet Singh
Please use command:  show module contentSwitchingModule 4 ft detail
The modules in FT will have same FT GROUP ID and usually it is recommended to have a different VLAN assigned for FT heartbeat exchange as well. So you can check manually on the basis of FT group ID which two modules are using it.
Another command which can be useful is: #show module contentSwitchingModule all ft
Kanwal
Jorge Bejarano
Level 10
Level 10
FT group 2, vlan 30
 This box is active
Jorge
