Issue with using the same cookie on different VIPS?
nygenxny123
Level 7
Level 7
We have 2 servers
rserver host server1
rserver host server 2
they both are associated on one serverfarm
serverfarm host CUSTOMER
rserver server1
rserver server2
We have multiple VIPS
sticky http-cookie customer cookie customer cookie
  cookie insert
  replicate sticky
  serverfarm customer
class-map match-all CUSTOMER1-VIP
  2 match virtual-address 172.20.10.24 tcp eq https
class-map match-all CUSTOMER2-VIP
  2 match virtual-address 172.20.10.23 tcp eq https
policy-map type loadbalance first-match CUSTOMER1-l7slb
  class class-default
    sticky-serverfarm customer cookie
policy-map type loadbalance first-match CUSTOMER2-l7slb
  class class-default
customer1 enters his vip 172.20.10.24/folder1
customer 2 enters his vip 172.20.10.23/folder2
both VIP go to the same serverfarm which has the same servers
the servers direct the request to the necessary folder
We are having issues with getting the needed response
Is there an issue with with my current configuration?
its very straightforward...multple VIPs to the same server/serverfarm
followed by the uri of the customer
would the cookie config cause an issue?
Surya ARBY
Level 10
Level 10
don't foget to use the "browser-expire" parameter to your cookie insertion. Otherwise your config is good, I doubt the issue comes from the ACE.
