keepalive problem
hassan_oudeh
Level 4
Level 4
hi guys,
please i have configured this keepalive and service as shown:
keepalive Server-1
type http
port 81
method get
uri "/HealthCheck2/HealthPageTest/Default.aspx"
ip address 10.0.207.71
active
service Server-1
port 81
keepalive method get
keepalive type named PreBancs1Keepalive
active
after configuring the keepalive the server become Alive (which is very good)
After some times (maybee 3 hours or less) the service become Down and when i make suspend and active to the keepalive it become Alive again ???
any idea pleass, urgent
Hasan Odeh
9 Replies 9
hassan_oudeh
Level 4
Level 4
sorry i made a mistake while pastin the config
keepalive Server-1
type http
port 81
method get
active
service Server-1
port 81
keepalive type named Server-1
active
hassan~
Could you try using "keepalive method head" instead of "keep alive method get"?
With Get method CSS computes an MD5 (Message Digest Algorithm Version 5)hash value on the page, and stores the hash value as a reference hash. Subsequent GETs require a 200 OK status and the "hash value to equal the reference hash value". If the 200 OK status is not returned, or if the 200 OK status is returned but the hash value is different from the reference hash value, the CSS considers the service down.
If the URI you are monitoring changes by only a bit then CSS will consider it down.
Hope it helps
Syed Iftekhar Ahmed
Dear Syed,
the customer is looking for GET for the keepalive,
But even if the hash value is not matched and the CSS consider it Down, by the next check it should came up again, but its not.
Am I right ?
i mean why after suspen and active it came back.
what i found also from the show keepalive during the service Down there is KeepAlive Error
Any idea ?
Hasan Mohammad Odeh
Suspending and then activating the service forces the CSS to recalculate the hash.
As long as the page remains the same CSS will mark them alive.As soon as there is a change, the new hash value will differ the earlier calculated value and CSS will mark the Server down.
In a nutshell
If the pages are dynamic you cant use the get method with CSS.
Syed Iftekhar Ahmed
yes Syed, i got your point
and yes the page is dynamic,
on the server they are doing some internal testing (for SQL and AD standalone servers) and they put the result into that page as true or false (true=200 false=something else) and CSS is checking that page.
So as i understan its a MUST to be HEAD ?
Yes...With dynamic page you cannot use Get.
Syed Iftekhar Ahmed
if you really need a GET, you can use a scripted keepalive. There a few of them available by default that you can use directly or rewrite to fit your need.
ie:
ap-kal-httplist 3 APR 07:25:14 1674
ap-kal-httptag 3 APR 07:25:14 1180
Gilles.
If you have to authenticate prior to getting to this uri would this config still work or what would be the work around for requiring an authentication
Thanks thumpercisco, i cant play around the authentication because the everything is in production now 🙂 but i didn't configure any http authentication.
i think it was a problem of get method, because i changed the method to head and i didn't face that problem anymore.
this is because as Efthikhar said i have a dynamic page for healthchek
