layer 7 class map on ace
networks
Visitor
would like to use layer 7 class map and policy on ace
requirement
have a single vip address 1.1.1.1 for url vprsoa.test.co.uk, vprgat.test.co.uk, vprgatadm.co.uk
what to use in LB so the above should work
also when i type vprsoa.test.co.uk/em it should be directed to the correct server farm
so /* for any of the above url should also work
what regular expressions to use
thanks in advance
shbadve
Level 2
Level 2
Example:
class-map match-all VIP
  2 match virtual-address 1.1.1.1 tcp eq www
class-map type http loadbalance match-all VPRSOA_EM
  2 match http header Host header-value "vprsoa.test.co.uk"
  4 match http url /em
policy-map type loadbalance first-match VPR_URL_SLB
  class VPRSOA_EM
    serverfarm FARM1
  class class-default
    serverfarm FARM_DEFAULT
policy-map multi-match VIP_SLB
  class VIP
    loadbalance vip inservice
    loadbalance policy VPR_URL_SLB
    loadbalance vip icmp-reply
In case each host name+URL needs to go to a different serverfarm then please create separate class-map for each.
Example:
class-map type http loadbalance match-all VPRSPA_TEST
  4 match http url /.*
  class VPRSOA_EM
    serverfarm FARM_EM
  class VPRSOA_TEST
    serverfarm FARM_TEST
  class class-default
Note: Order of class-map is important.
Adding Case Insensitive:
parameter-map type http HTTP-Params
case-insensitive
  class VIP
    appl-parameter http advanced-options HTTP-Params
Hope this helps.
Thanks - Shubha
shbadve
Level 2
Level 2
Example:
  class VPRSOA_EM
    serverfarm FARM1
  class class-default
  class VIP
Example:
  class VPRSOA_EM
    serverfarm FARM_EM
  class VPRSOA_TEST
  class class-default
case-insensitive
  class VIP
Hope this helps.
Thanks - Shubha
Thanks for the reply
other 2 url are working but
but unosoagat.mfltest.co.uk/* isnt working, i am not sure if its the server or the config
btw: all 3 urls are pointed to the same server farm, for stickiness i have used
sticky http-cookie SFARM-UNOgateway-endpoint-STICKY SFARM-COOKIE-INSERT-UNO-gateway-endpoint-7777
  cookie insert browser-expire
  replicate sticky
  serverfarm unogateway_adm_int
sticky http-cookie SFARM-UNOgatewayADM-endpoint-STICKY SFARM-COOKIE-INSERT-UNO-gatewayADM-endpoint-7777
  replicate sticky
sticky http-cookie SFARM-UNOgatewayINT-endpoint-STICKY SFARM-COOKIE-INSERT-UNO-gatewayINT-endpoint-7777
  replicate sticky
class-map type http loadbalance match-all L7unosoagat
  2 match http Host header-value "unosoagat.mfltest.co.uk"
  3 match http url /.*
class-map type http loadbalance match-all L7unosoagatadm
  2 match http Host header-value "unosoagatadm.mfltest.co.uk"
class-map type http loadbalance match-all L7unosoagatint
   2 match http Host header-value "unosoagatint.mfltest.co.uk"
I would suggest that you check the "show service-policy detail" output to see if the hit count for class L7unosoagat is incrementing or not.
If it is and the connection is not successful then check the "show serverfarm detail" for any failed conenctions.
However if the hit count is not incrementing then a client side capture would be helpful to see how the host name looks like.
Hope this helps.
Thanks. - Shubha
