LD Troubleshooting for LocalDirector
4gluna
I kwon if changing routers or servers may cause access problems if LocalDirector is using an old MAC address. I use the no arp or clear arp command to clear the ARP cache , bot this no resolve my proble can´t access
for my Servers ,...
s.jankowski
Level 4
Level 4
Have you looked at the arp cache to see if the mac address is corrected? If not, it might be a bug in the code version you’re running. You might just need to reload the box. What about the routers arp cache?
