licensing vdc on Nexus 7700
nuno.santos
I'm having some difficult to understand what realy means the output I get from "show licenses usage" regarding VDC-LICENSES on nexus 77K:
Feature                                             Ins      Lic   Status Expiry Date Comments
                                                        Count
MPLS_PKG                                         No    -   Unused             -
STORAGE-ENT                                   No    -   Unused             -
VDC_LICENSES                                 Yes   4   In use Never       -
FCOE-N7K-F248XP                            Yes   4   Unused Never       4 license(s) missing
ENHANCED_LAYER2_PKG                 Yes   -   Unused Never       -
TRANSPORT_SERVICES_PKG            Yes   -   Unused Never       -
LAN_ENTERPRISE_SERVICES_PKG   Yes   -   Unused Never       -
from the above output I've expected I can create up to 4 non-default VDC + 1 default admin VDC (lic number =4 as see above). I've tried to create the vdc number 6 and works! It i s active and works! So my question is if by default exists already 4+1 VDCs license and after licensing I get 8+1?
The result from  "sh license usage vdc-all VDC_LICENSES " is also curious as presented below where I see only vdc_3; 4; 5 and 6 being allocated to the VDC_LICENSE. The VDC 1(Admin) and VDC2 don't need any license?:
Application              Vdc
vdc_3                    mgmt1-dc1
vdc_4                    mgmt1-dc1
vdc_5                    mgmt1-dc1
vdc_6                    mgmt1-dc1
The following vdcs were created:
mgmt1-dc1# sh vdc
Switchwide mode is f2e f3
vdc_id  vdc_name                          state               mac                 type        lc
1       mgmt1-dc1                         active              00:2a:6a:a3:ef:41   Admin       None
2       core-dc1                          active              00:2a:6a:a3:ef:42   Ethernet    f2e f3
3       pe1-dc1                           active              00:2a:6a:a3:ef:43   Ethernet    f3
4       trans1-dc1                        active              00:2a:6a:a3:ef:44   Ethernet    f3
5       agg1-dc1                          active              00:2a:6a:a3:ef:45   Ethernet    f2e f3
6       5                                 active              00:2a:6a:a3:ef:46   Ethernet    f2e f3
I'm using N77-SUP2E on brand new nexus C7706 running 6.2.8.
Many thanks,
best regards,
Nuno Santos
0 Replies 0
