Load Balance HTTPS servers with redirection
isaidimonone
Community Member
I have been tasked with ACE configuration at work as the prior go-to guy for load balancing is no longer available. Trouble is, I have little idea what I’m doing when it comes to the ACE. So, forgive me if the question I have is super basic. After doing some research I put together a LB config, but its not working.
I was trying to load balance 10 servers, split into groups of 2 using 5 VIPS (1 VIP for each group of 2 servers). The servers serve an ssl web app.
Below is my configuration. What am I doing wrong? Does the config have any glaring errors? I've been staring at this thing on and off for a week  and searching these forums trying to figure it out.
Any help provided will greatly appreciated.
probe tcp probe_443
  port 443
  interval 30
  passdetect interval 5
probe https probe_https_test
  interval 30
  ssl version all
  request method get url /test.html
  expect status 200 200
rserver host QA-1.1
ip address 10.200.162.126
inservice
rserver host QA-1.2
ip address 10.200.162.127
inservice
rserver redirect QA-group_1_redirect_rserver
webhost-redirection https://10.37.5.73/ 302
  inservice
rserver host QA-2.1
ip address 10.200.162.22
inservice
rserver host QA-2.2
ip address 10.200.162.240
inservice
rserver redirect QA-group_2_redirect_rserver
webhost-redirection https://10.37.5.74/ 302
  inservice
rserver host QA-3.1
ip address 10.200.162.181
inservice
rserver host QA-3.2
ip address 10.200.162.50
inservice
rserver redirect QA-group_3_redirect_rserver
webhost-redirection https://10.37.5.75/ 302
  inservice
rserver host QA-4.1
ip address 10.200.162.23
inservice
rserver host QA-4.2
ip address 10.200.162.241
inservice
rserver redirect QA-group_4_redirect_rserver
webhost-redirection https://10.37.5.76/ 302
  inservice
rserver host QA-5.1
ip address 10.200.162.182
inservice
rserver host QA-5.2
ip address 10.200.162.51
inservice
rserver redirect QA-group_5_redirect_rserver
webhost-redirection https://10.37.5.77/ 302
  inservice
serverfarm host SF_QA-group_1_HTTPS
failaction reassign
predictor leastconns
probe probe_443
probe probe_https_test
rserver QA-1.1 443
inservice
rserver QA-1. 2 443
inservice
serverfarm host SF_QA-group_2_HTTPS
failaction reassign
probe probe_443
rserver QA-2.1 443
inservice
rserver QA-2. 2 443
inservice
serverfarm host SF_QA-group_3_HTTPS
failaction reassign
probe probe_443
rserver QA-3.1 443
inservice
rserver QA-3. 2 443
inservice
serverfarm host SF_QA-group_4_HTTPS
failaction reassign
probe probe_443
rserver QA-4.1 443
inservice
rserver QA-4. 2 443
inservice
serverfarm host SF_QA-group_5_HTTPS
failaction reassign
probe probe_443
rserver QA-5.1 443
inservice
rserver QA-5. 2 443
inservice
serverfarm redirect SF_ QA-group_1_REDIRECT
rserver QA-group_1_redirect_rserver
inservice
serverfarm redirect SF_ QA-group_2_REDIRECT
rserver QA-group_2_redirect_rserver
inservice
serverfarm redirect SF_ QA-group_3_REDIRECT
rserver QA-group_3_redirect_rserver
inservice
serverfarm redirect SF_ QA-group_4_REDIRECT
rserver QA-group_4_redirect_rserver
inservice
serverfarm redirect SF_ QA-group_5_REDIRECT
rserver QA-group_5_redirect_rserver
inservice
sticky ip-netmask 255.255.255.255 address source SRC_ QA-group_1_STICKY
serverfarm SF_ QA-group_1_HTTPS
timeout 30
replicate sticky
sticky ip-netmask 255.255.255.255 address source SRC_ QA-group_2_STICKY
serverfarm SF_ QA-group_2_HTTPS
timeout 30
replicate sticky
sticky ip-netmask 255.255.255.255 address source SRC_ QA-group_3_STICKY
serverfarm SF_ QA-group_3_HTTPS
timeout 30
replicate sticky
sticky ip-netmask 255.255.255.255 address source SRC_ QA-group_4_STICKY
serverfarm SF_ QA-group_4_HTTPS
timeout 30
replicate sticky
sticky ip-netmask 255.255.255.255 address source SRC_ QA-group_5_STICKY
serverfarm SF_ QA-group_5_HTTPS
timeout 30
replicate sticky
class-map match-all QA-group_1_HTTP
3 match virtual-address 10.37.5.73 tcp eq www
class-map match-all QA-group_1_HTTPS
3 match virtual-address 10.37.5.73 tcp eq https
class-map match-all QA-group_2_HTTP
3 match virtual-address 10.37.5.74 tcp eq www
class-map match-all QA-group_2_HTTPS
3 match virtual-address 10.37.5.74 tcp eq https
class-map match-all QA-group_3_HTTP
3 match virtual-address 10.37.5.75 tcp eq www
class-map match-all QA-group_3_HTTPS
3 match virtual-address 10.37.5.75 tcp eq https
class-map match-all QA-group_4_HTTP
3 match virtual-address 10.37.5.76 tcp eq www
class-map match-all QA-group_4_HTTPS
3 match virtual-address 10.37.5.76 tcp eq https
class-map match-all QA-group_5_HTTPS
3 match virtual-address 10.37.5.77 tcp eq www
3 match virtual-address 10.37.5.77 tcp eq https
class-map type management match-any remote-management
2 match protocol http any
3 match protocol https any
4 match protocol icmp any
5 match protocol snmp any
6 match protocol ssh any
policy-map type management first-match remote-access
class remote-management
permit
policy-map type loadbalance first-match QA-group_1_REDIRECT
class class-default
serverfarm SF_ QA-group_1_REDIRECT
policy-map type loadbalance first-match QA-group_2_REDIRECT
class class-default
serverfarm SF_ QA-group_2_REDIRECT
policy-map type loadbalance first-match QA-group_3_REDIRECT
class class-default
serverfarm SF_ QA-group_3_REDIRECT
policy-map type loadbalance first-match QA-group_4_REDIRECT
class class-default
serverfarm SF_ QA-group_4_REDIRECT
policy-map type loadbalance first-match QA-group_5_REDIRECT
class class-default
serverfarm SF_ QA-group_5_REDIRECT
policy-map multi-match SERVICE_VIPS
class QA-group_1_HTTPS
    loadbalance vip inservice
    loadbalance policy HTTPS_ QA-group_1_HTTPS _L7_BALANCED
    loadbalance vip icmp-reply
    nat dynamic 1 vlan 25
    loadbalance policy QA-group_1_REDIRECT
class QA-group_2_HTTPS
    loadbalance policy HTTPS_ QA-group_2_HTTPS _L7_BALANCED
    loadbalance policy QA-group_2_REDIRECT
class QA-group_3_HTTPS
    loadbalance policy HTTPS_ QA-group_3_HTTPS _L7_BALANCED
    loadbalance policy QA-group_3_REDIRECT
class QA-group_4_HTTPS
    loadbalance policy HTTPS_ QA-group_4_HTTPS _L7_BALANCED
    loadbalance policy QA-group_4_REDIRECT
class QA-group_5_HTTPS
interface vlan 25
  ip address 10.37.5.72 255.255.255.0
    access-group input everyone
  service-policy input remote-access
  service-policy input SERVICE_VIPS
  no shutdown
ip route 0.0.0.0 0.0.0.0 10.37.5.1
19 Replies 19
Fnu,
The default gatway of the servers is not the ACE. The ace shares the same defautl gateway as the servers.
Below is the ouput from show conn address:
conn-id    np dir proto vlan source                destination           state
623415     2  in  TCP   25   172.20.45.194:62665   10.37.5.93:443        SYNSEEN
1526026    2  out TCP   25   10.37.5.111:443       172.20.45.194:62665   INIT
1899590    3  in  TCP   25   172.20.45.194:62664   10.37.5.93:443        SYNSEEN
1117936    3  out TCP   25   10.37.5.111:443       172.20.45.194:62664   INIT
340226     4  in  TCP   25   172.20.45.194:62666   10.37.5.93:443        SYNSEEN
1785542    4  out TCP   25   10.37.5.111:443       172.20.45.194:62666   INIT
Hi John,
So that's a problem then. Return traffic from server should also pass through ACE. ACE is not seeing the return traffic. This is Asymmetric routing. You will either have to do src nat or change the default gateway of servers to ACE. Try changing for one serverfarm (two servers in a serverfarm) and test again. If that works you know this is the issue or you can add a route on the server as well.
Kanwal
I added source nat and the redirection is working now. However, I have made an error in the configuration which is preventing one of the server farms from being used. I tried to delete the config line in questions, but the ACE said it was in use. Is there way to free it, so I can delete it and re enter with correct info?
I tried  "no class-map match-all QA-group_4_HTTPS"
Error: class-map 'QA-group_4_HTTPS' is in use. Deletion not allowed
3 match virtual-address 10.37.5.96 tcp eq www
Hi John,
Remove the class map from policy map and then remove it. That should do the trick.
Kanwal
Hi Fnu,
I've been following this post to figure out the problem with my configuration.   I have a VIP redirecting to 2 real servers 172.x.x.114 and 115 respectively.   The url to be accessed is http://ofrv.a.b/portal/page.    This has to be redirected to the 2 servers on ofr1.a.b and ofr2.a.b on port 8090.     This is where I have a problem.    I'm a newbie to ACE, so I'm lost with the configuration.    The current configuration was configured by someone else and since the guy is on a vacation I'm having to fix this port redirection.  Oracle support said it needs NAT bounce back rule on the cisco LBR.  Is this the same as the one in this post.  I'm not exactly sure how this is to be done.   Kindly help me figure out the problem with the configuration.
Generating configuration....
resource-class COM
  limit-resource all minimum 10.00 maximum unlimited
boot system image:c4710ace-mz.A3_2_0.bin
hostname ACE
interface gigabitEthernet 1/1
  no shutdown
interface gigabitEthernet 1/2
  description Server-Side
  switchport access vlan 2
  no shutdown
interface gigabitEthernet 1/3
  qos trust cos
  no shutdown
interface gigabitEthernet 1/4
  shutdown
context Admin
  member COM
access-list ALL line 8 extended permit ip any any
access-list ALL line 16 extended permit icmp any any
probe icmp ICMP_PROBE1
  description *** Probe for icmp health monitoring ***
  interval 5
  faildetect 2
  passdetect interval 10
  passdetect count 2
probe http OFR-HTTP3
  interval 15
  passdetect interval 60
  request method get url http://ofr1.a.b:8090
  expect status 200 201
  open 1
probe http OFR-HTTP4
  interval 15
  request method get url http://ofr2.a.b:8090
  open 1
optimize
  appscope-log
  debug-level 5
rserver redirect OFR-Server-redirect
  webhost-redirection http://ofrv.a.b/portal/page 302
  inservice
rserver host OFR1-Server
  description Form& Reports Server
  ip address 172.x.x.114
  inservice
rserver host OFR2-Server
  ip address 172.x.x.115
  inservice
serverfarm redirect OFR-Server_REDIRECT
  rserver OFR-Server-redirect
    inservice
serverfarm host Reports-SF2
  description Forms&Reports Services Farm
  rserver OFR1-Server 7001
    probe ICMP_PROBE1
    inservice
  rserver OFR2-Server 7001
    probe ICMP_PROBE1
    inservice
serverfarm host Reports-SF2-3
  rserver OFR1-Server 9002
    probe ICMP_PROBE1
    inservice
  rserver OFR2-Server 9002
    probe ICMP_PROBE1
    inservice
serverfarm host Reports-SF2-4
  rserver OFR1-Server 9003
    probe ICMP_PROBE1
    inservice
  rserver OFR2-Server 9003
    probe ICMP_PROBE1
    inservice
serverfarm host Reports-SF2-5
  probe OFR-HTTP3
  probe OFR-HTTP4
  rserver OFR1-Server 8090
    probe ICMP_PROBE1
    inservice
  rserver OFR2-Server 8090
    probe ICMP_PROBE1
    inservice
serverfarm host Reports-SF2-two
  rserver OFR1-Server 7002
    probe ICMP_PROBE1
    inservice
  rserver OFR2-Server 7002
    probe ICMP_PROBE1
    inservice
sticky http-cookie Reports HTTP-Cookie-Sticky
  cookie insert browser-expire
  timeout 720
  timeout activeconns
  serverfarm Reports-SF2
sticky http-cookie Reports HTTP-Cookie-Foram-two
  timeout 720
  timeout activeconns
  serverfarm Reports-SF2-two
sticky http-cookie Portal HTTP-Cookie-Portal
  timeout 720
  timeout activeconns
  serverfarm Portal-SF1
sticky http-cookie Portal HTTP-Cookie-Portal-two
  timeout 720
  timeout activeconns
  serverfarm Portal-SF1-two
sticky http-cookie Reports HTTP-Cookie-SF2-3
  timeout 720
  timeout activeconns
  serverfarm Reports-SF2-3
sticky http-cookie Reports HTTP-Cookie-SF2-4
  timeout 720
  timeout activeconns
  serverfarm Reports-SF2-4
sticky http-cookie INFR HTTP-Cooki-SF1
  timeout 720
  timeout activeconns
  serverfarm INFR-SF1
sticky http-cookie INFR HTTP-Cooki-SF2
  timeout 720
  timeout activeconns
  serverfarm INFR-SF2
sticky http-cookie INFR HTTP-Cooki-SF3
  timeout 720
  timeout activeconns
  serverfarm INFR-SF3
sticky http-cookie INFR HTTP-Cooki-SF4
  timeout 720
  timeout activeconns
  serverfarm INFR-SF4
sticky http-cookie Reports HTTP-Cookie-SF2-5
  timeout 720
  timeout activeconns
  serverfarm Reports-SF2-5
class-map match-any OFR-VIP
  4 match virtual-address 172.x.x.140 any
class-map match-any OFR-VIP-3
  2 match virtual-address 172.x.x.140 tcp eq 9002
class-map match-any OFR-VIP-4
  2 match virtual-address 172.x.x.140 tcp eq 9003
class-map match-any OFR-VIP-5
  2 match virtual-address 172.x.x.140 tcp eq 8090
  3 match virtual-address 172.x.x.140 tcp eq www
  4 match virtual-address 172.x.x.140 tcp eq https
class-map match-any OFR-VIP-two
  2 match virtual-address 172.x.x.140 tcp eq 7002
class-map type management match-any remote_access
  201 match protocol xml-https any
  202 match protocol icmp any
  203 match protocol telnet any
  204 match protocol ssh any
  205 match protocol http any
  206 match protocol https any
  207 match protocol snmp any
policy-map type management first-match remote_mgmt_allow_policy
  class remote_access
    permit
policy-map type loadbalance first-match OFR-Server_REDIRECT
  class class-default
    serverfarm OFR-Server_REDIRECT
policy-map type loadbalance first-match OFR-VIP-l7
  class class-default
    sticky-serverfarm HTTP-Cookie-SF2-3
policy-map type loadbalance first-match OFR-VIP-l7slb
  class class-default
    sticky-serverfarm HTTP-Cookie-Sticky
policy-map type loadbalance first-match OFR-VIP-l7slb-3
  class class-default
policy-map type loadbalance first-match OFR-VIP-l7slb-4
  class class-default
    sticky-serverfarm HTTP-Cookie-SF2-4
policy-map type loadbalance first-match OFR-VIP-l7slb-5
  class class-default
    sticky-serverfarm HTTP-Cookie-SF2-5
policy-map type loadbalance first-match OFR-VIP-l7slb-two
  class class-default
    sticky-serverfarm HTTP-Cookie-Foram-two
policy-map multi-match int2
  class OFR-VIP
    loadbalance policy OFR-VIP-l7slb
  class OFR-VIP-two
    loadbalance policy OFR-VIP-l7slb-two
  class OFR-VIP-3
    loadbalance policy OFR-VIP-l7slb-3
  class OFR-VIP-4
    loadbalance policy OFR-VIP-l7slb-4
  class OFR-VIP-5
    loadbalance policy OFR-Server_REDIRECT
interface vlan 2
  description MGT-Interface
  ip address 172.x.x.142 255.255.0.0
  access-group input ALL
  nat-pool 1 172.x.x.143 172.x.x.143 netmask 255.255.255.255 pat
  service-policy input remote_mgmt_allow_policy
  service-policy input int2
  no shutdown
ip route 0.0.0.0 0.0.0.0 172.x.x.1
Any help would be greatly appreciated.
Thanks and regards
Sbegum
