Load Balance Reverse Poxy using ACE and HTTP Header Sticky
Dear all,
I have a reverse proxy that makes HTTP and HTTPS requests to an ACE.
For implement persistence I want to configure HTTP HEADER Stickyness using the X-Forwarder-For information but I don't know:
  • How to implement it ( I'l apreciate a little example about it).
  • Which values I need for OFFSET and LENGHT fields.
Can you help me please?
Thanks a lot!!
5 Replies 5
Cesar Roque
Level 4
Level 4
Hi David,
Here is a basic HTTP configuration inserting the x-forward-for:
serverfarm host sample
  rserver test1
    inservice
  rserver test2
    inservice
class-map match-any sample
  3 match virtual-address 170.173.175.65 tcp eq www
policy-map type loadbalance first-match test
  class class-default
    serverfarm sample
    insert-http x-forward header-value "%is"
policy-map multi-match int901
  class sample
    loadbalance vip inservice
    loadbalance policy test
    loadbalance vip icmp-reply active
Cesar R
ANS Team
--------------------- Cesar R ANS Team
Hi Cesar.
Thanks a lot for your answer but I think you misunderstand the question or I'm not explaninig very well
I don't need to insert anything.
The serverfarm X will be accesed by a reverse proxy. This reverse proxy already inserts the X-Forearder-From header, so the request from the reverse proxy comes with this header to the serverfarm X.
The problem is that now, the serverfarm X sticky the client based on source IP. This is a wrong behavior becasue all the request comes form the same source (Reverse proxy) and all the load forwards to the same real IP address.
This is because I want to change the sticky from source IP to HTTP header and looks for the X-Forwarder-For filed.
Hop it will clarify the question!
Hi David,
Actually, this should be easy to do using stickiness based on cookies.  The sticky group should look like this:
sticky http-cookie [cookie-name] [sticky group name]
  cookie insert browser-expire
  serverfarm [serverfarm name]
Cesar R
ANS Team
mruuth
Hi David,
here you have an exampel.
sticky http-header X-Forwarded-For SH-EXAMPEL
  header offset 0 length 15
  serverfarm SFPfarm
  timeout 60
  replicate sticky
  policy-map type loadbalance first-match VEXAMPEL-l7slb
  class class-default
    sticky-serverfarm SH-EXAMPEL
Mats
Dear.
I'm not sure what is the best solution for this case:
- Load Balance using HTTP Header.
- Load BAlance using cookie.
I'm sure that the reverse proxy insert the X-Forwarder-For but I don't know how cookie insertion works.
Thanks!!
