Load Balancer for Primary and Secondary Server
s.aliyarukunju
Dear Experts,
In our organiation , we have ACE module that is configured with load balancing the server farm ( 2 webserver  , WEB01 and WEB02 ) in round-robin predictor method.
Currenly the loadbalancing between WEB01 and WEB02 are working perfect with round-robin mode.
Now their is a requirement to use this webserver in primary / secondary mode. ie WEB01 should be active all the time and process the web request.  WEB02 should be in standby and active only when WEB01 is down or not reachable.
Then i re-configured the rserver with weigth value of 100 on WEB01 and and  weigth value of 1 on WEB02.
Now i can see that the all the web request is comming to WEB01.
Could you please advice whether above configured one is the right method to deploy/configure the ACE as per the new requirement ?
Becuase i do not want any request to go to WEB02 untill the WEB01 is down.
Kindly advice.
Jorge Bejarano
Level 4
Level 4
Hey,
You may want to check the following post:
https://supportforums.cisco.com/thread/2048804
Here you have a sample:
rserver WEB01
ip address 10.20.20.2
inservice
rserver WEB02
ip address 10.20.20.3
  inservice
serverfarm host WEB01-PRIMARY
  rserver WEB01
    inservice
serverfarm host WEB02-SECONDARY
  rserver WEB02
    inservice
policy-map type loadbalance http first-match WEB-SERVICES
class class-default
serverfarm WEB01-PRIMARY backup WEB02-SECONDARY
Jorge
Jorge Bejarano
Level 4
Level 4
Hey,
rserver WEB01
inservice
rserver WEB02
  inservice
  rserver WEB01
    inservice
  rserver WEB02
    inservice
class class-default
Jorge
Thanks Jorge and Ajay for your help on my requirment.
I have done the configuration based on the Jorge's advice and it is working fine now.Many thanks !!!
One doubt i have now is , if the primary server goes down , the ACE will direct the traffic to secondary/standby server and process the request.
But when the primary server comes UP , do they switchover to primary ? Or seconday server will handle the request till it go down ?
If primary server process the request when it comes back , what will happen to the inital connection request that was prevoulsy handled by the standby server ?
Could you kindly clarify on this ?
Kind Regards,
ajayku2
I believe this would suite you.
ace-1/test(config)# serverfarm host testserverfarm
ace-1/test(config-sfarm-host)# rserver WEB01
ace-1/test(config-sfarm-host-rs)# backup-rserver
WEB01 WEB02
ace-1/test(config-sfarm-host-rs)# backup-rserver WEB02
ace-1/test(config-sfarm-host-rs)# end
ace-1/test# sh run serverfarm
Generating configuration....
  probe tcp
  rserver WEB01
    inservice
  rserver WEB02
    inservice standby
Hope that helps,
regards,
Ajay Kumar
