Load Balancers redirects for images
ptaylor51
Presently we are reyling on our reverse proxies to direct traffic to our web pages (from the Load balancers), the problem is that the RP's are overloaded when dealing with the images, i would like to know how to bypass the RP when loading the images and will this effect how the RP's will be used for loading regular pages.
Gilles Dufour
not sure what is your network currently.
Is it something like client ----- RP ----- CSS ----- Servers ?
How does the client get to the RP ? Are they setup to go there directly or is
it the CSS that redirect them to the RP ?
There is a way on the CSS to match extension like jpeg, gif, ... and we could use this to have a different rule for images and other type of data, but to make it work, we would need the client to get to the CSS directly, then the CSS will either server the client directly for images and redirect to the RP for the rest.
Gilles.
Gilles thank you for the reply,
Yes in fact the client is hitting the redundent LB (CSS's) then if it is secure SSL port 443 it goes to the SCA 's first ,if its just on port 80 it then is distributed across two RP. The RP then send the request to the web servers, this is were i'm having the problem, the RP are overloaded with images to get .
Appreciate the solution if you can help.
Peter
The header field group solution is not exactly the right one.
Below is what should work for your situation.
The idea is to create 2 content rules.
The regular one will loadbalance HTTP request to RP and the 2nd one will match only HTTP request to images and will Loadbalance directly to the end
servers bypassing the RP.
Solution with EQL
eql images
extension bmp "Bitmap Image"
extension gif "GIF Image image/gif"
extension jpeg "JPEG image image/jpeg"
extension jpg
extension jpe
extension jfif
extension pjpeg
owner mycompany
content www_images
vip address x.x.x.x
proto tcp
port 80
url "/*" eql images
add service WWW_Server1
content www
vip address x.x.x.x
proto tcp
port 80
url "/*"
add server WWW_RP1
Let me know if this works.
Gilles.
