load-balancing in the same IP subnet
ROMAN TOMASEK
Can I use load-balancing in the same IP subnet? I have the servers and client in the same IP subnet. I'd like to load-balance client traffic to server traffic. I also need to load balance traffic between servers. Is possible to configure it only in one VLAN?
For example:
CSS:
interface 4/2
circuit VLAN1
ip address 10.0.0.10 255.255.255.0
service s1
ip address 10.0.0.101
active
service s2
ip address 10.0.0.102
active
service s3
ip address 10.0.0.103
active
service s4
ip address 10.0.0.104
active
owner test
content client
vip address 10.0.0.3
add service s1
add service s2
active
content servers
vip address 10.0.0.4
add service s3
add service s4
active
Cat6500:
interface FastEthernet4/1 - clients
no ip address
switchport
switchport mode access
spanning-tree portfast
interface FastEthernet4/2 - servers
no ip address
switchport
interface FastEthernet4/3 - CSS
no ip address
switchport
interface Vlan1
ip address 10.0.0.1 255.255.255.0
ip policy route-map pokus
access-list 101 permit tcp any eq 80 any
route-map pokus permit 10
match ip address 101
set ip next-hop 10.0.0.10
Thank you
Roman
Configuration on the slide is OK. On the c6500 are interfaces in *switchport* mode (the same situation on the CSS). In other words, information about VLAN is not 'transferred' to the CSS.
for CSS are servers and clients accessible through vlan10, but in real are server located in vlan20 and clients in vlan10. this method is called 'transparent bridge mode' (I had use it only ones, or twice).
I think, more preferred for you (because you have only one link between css and c6500) is bridge mode (no transparent bridge mode). That's only my recommendation.
regards,
martin
9 Replies 9
Martin Kyrc
Level 3
Level 3
Hi Roman,
yes, it's possible.
1. for load-balancing (LB) in the same IP subnet use 'bridge mode' (two vlans, one ip subnet)
2. do you need LB server's traffic? that means, src (server) connect VIP and dst is the same server (or server in the same ip pool and vlan)? sure? in this case is necessary to use 'client nat', because src connect vip (css), css connect dst, but response withour client nat will be answered direct to the src and not through css.
I'm not sure, if this second answer is useful for you.
martin
Thank you.
So I have to use two vlans:-( Can you send me the configuration example of the bridge mode?
Thank you
Roman
Can I use bridge mode in the one-arm topology? I have CSS connected only with one link with the Cat6500. I have the problem to understand why there are two links with the same VLAN on the picture, which is in the attachments.
Thank you.
Here is the picture.
yes, it's possible - use trunk with two VLANs (slide 9). or you can use 'transparent' mode (slide 11 - your attachment).
answer to your question (I have the problem to understand why there are two links with the same VLAN on the picture):
on the switch are two port interfaces in *switchport* mode (not trunk). now is it clearly?
result:
both methods (bridge mode with two vlans, or transparent bridge mode) use two vlans. it's on you, which type is for you preferred.
my recommendation is - use first method - one link to CSS with trunk configured in bridge mode (one ip subnet, two vlans, default gw for servers isn't css, but parent router)
martin
thank you for your exhausting answer.:-) I have the last question (I promise): in the slide 11 - on the CSS is:
interface 1/1
bridge vlan 10
interface 1/2
bridge vlan 10
and on the switch:
int FE 4/1
switchport access vlan 10
int FE 4/2
switchport access vlan 20
here are different vlans - on css is only vlan 10 and on the switch are vlans 10, 20;-( Is the configuration correct??
I think that good config is following:
interface 1/2
bridge vlan 20
Thank you
Roman
regards,
martin
thank you for all
Roman
