Local Director reloading after running show commands
I have a pair of 420's running 4.2.5 & I am experiencing when being in the LD & running show commands the Active will reload & the secondary takes over. Has anybody experienced this problem?
owillins
Level 6
Level 6
Are you sure that the reload happens when a show command is typed? Have you seen any other messages? I am asking this because I have not heard of a reload with a show command. It could also be possible that some other procesor/memory intensive task is running and the show command was entered at the same time. You could check for bugs and upgrade if necessary.
