logging buffered not displayed
eng.taher_gabr
Level 2
Level 2
                   i have cisco catalyst 4506 switch and i run no logging by mistake and i am trying to enable logging again but not displayed at all
7 Replies 7
Leo Laohoo
logging enable
yes logging on
every thing is enable but no loggin messge appears only specific types of messages not all
Yoy need to set the level of messages
type in   "logging buffered ?"
then choose level as below
  <0-7>              Logging severity level
  <4096-2147483647>  Logging buffer size
  alerts             Immediate action needed           (severity=1)
  critical           Critical conditions               (severity=2)
  debugging          Debugging messages                (severity=7)
  emergencies        System is unusable                (severity=0)
  errors             Error conditions                  (severity=3)
  informational      Informational messages            (severity=6)
  notifications      Normal but significant conditions (severity=5)
  warnings           Warning conditions                (severity=4)
What specific loggings are you looking for?
By default, interfaces on line cards for 4500 and 6500 are disabled.
To enable it, you need to go into the interface-level and enter the command "logging event link-status".  When you enable this command everytime the interface would go either down or up you'll see a few lines appear in the logs.
i already enable debugging level but not diaplayed
Have you tried this interface-level configuration command?
i will enable logging event link-status but what about other notifications
thanks
