Losing RDP connections randomly
thijn_moons
We have a cluster of MS terminal servers (5) behind a CSS and recently we have experiencing disconnects from a existing terminal server session. We have this config running for more than 2 years now and never had any problems with it. The only thing that has been changed is that the number of sessions has increased in the last week.
Attached the running config of the CSS.
We think that possibly 2 things can happen:
1) The CSS is trying to migrate the RDP session to another terminal server. This can be solved by using the sticky commands?
2) The CSS is terminating the flow? This can be solved by using the flow commands?
As anyone familiar with this problem and how did you solve this?
Thijn Moons
Not applicable
configure the
(config-owner-content) flow-timeout-multiplier
which is explained in the below link
http://www.cisco.com/univercd/cc/td/doc/product/webscale/css/css_720/cmdrefgd/cmdowcnt.htm#1140473
