management port on CSS 11150
kope
I have a simple question. Can someone tell me how to access the management port on the css 11150?
I configured the ip and mask on the management port and condigured my laptop for a ip on the same network. But i am unable to connect.
Gilles Dufour
what do you mean by connect ?
Are you trying telnet or HTTP ?
Are you able to ping ?
Is the interface showing up ?
Try 10Mb Half duplex set manually and see if it works.
Also, did you reboot the CSS after configuring the ip address/mask for the management interface ?
Gilles.
