Maximum session count for Optimization on WAAS
joepena2012
Level 3
Level 3
Hi all, i've currently two different types of hw in use.
WAE612 an NM-WAE502.
now i want to know the maximum session count for a WAE 512.
On 502 we have a maximum of 500 sessions
On 612 we have a maximum of 6000 sessiones.
could you give me the maximum session count on WAE512?
thx in advance
Dieter
2 Accepted Solutions
cstockwe
Level 2
Level 2
Optimized TCP connection capacity for a 512 (1GB) is 750 and for a 512 (2GB) is 1500.
The figure you quote for the 612 is for the 4GB model. With 2GB it is 2000.
PT traffic does not count against your max optimized session count.
You can also use the redirect-list functionality for WCCP which is basically an extended ACL to deny traffic from being redirected.
Using either method, I usually exclude all real time/management traffic: telnet, ssh, snmp, snmp traps, bgp, etc. You can do your denies by source/dest IP or Port.
Hope that helps,
Dan
cstockwe
Level 2
Level 2
thx for your help
Hmm, so i think it's the best to replace the NM due a WAE512.
however, i've currently the problem, that the TFO session count reaches the maximum a few times per day.
Now the question is:
What is the best way to avoid a TFO session exceed?
Is it O.K. to modify the policy. The Idea is to pass through traffic, which has only a poor benefit of WAAS (such as SAP).
The question here is: Has a pass through on the policy any impact to the TFO counter?
The second idea is to redirect only definded traffic via WCCP? Is there a way to do it in this way?
thanks for your help
Hope that helps,
Dan
