Memory question in a SCM Module on a 11800
pgarcia
Hi, I get this return when I issue a show system-resources command
System Resources for 7/1:
Installed Memory: 67,108,864 (64 MB)
Free Memory: 2,245,136 (2 MB)
CPU: 0%
Buffer Statistics:
Buffer Pool: 0
Size: 256 Total:1000 Available:1000 Failures: 0 Low Buffer Count: 983
Buffer Pool: 1
Size:1600 Total:2500 Available:2500 Failures: 0 Low Buffer Count: 2456
I think there's a very little memory left, I have no isues about rebooting.
It's recommendable to upgrade to 128 Mb. in the SCM ?
How can I do it ?
Thanks, Pablo
lynchp
Pablo,
For optium operation you should upgrade the memory to 128M. There is a part number for this,
CSS8-SCM-MEM-128M=
Cheers
Phil Lynch
Cisco Systems
