NAT confusion
shathaway
I apologize if this is a newbie question that has been asked a thousand times, but...
I have inherited a one-armed setup (11501) with this unit out on a DMZ.
It will be accessed both from the internet, and the inside network. (10.x.x.x)
I have two servers, app1 (192.168.1.10) and app2 (192.168.1.12) running Oracle IAS, and I want them to
appear as APP (192.168.1.4). I have tried several configurations from the documentation, and from here and they either don't work at all (no content), or eventually the real server's address gets exposed.
(if I start out at APP.my.domain, at some point I am told I am talking to app1.my.domain)
I would really rather not change the topology if possible, as it would mean all night in a data center 2hrs away...
Has anyone been able to do this? What am I missing?
Thanks in Advance. Below is the relevant part of my current config (which does not work) I have tried "add service app1" and "add destination service app1", ACL or no ACL, etc.
!************************** SERVICE **************************
service app1
ip address 192.168.1.10
string cookieapp1
active
!*************************** GROUP ***************************
group servers
vip address 192.168.1.4
active
!**************************** ACL ****************************
acl 1
clause 10 permit any 192.168.1.8 255.255.255.248 destination any sourcegroup servers
apply circuit-(VLAN1)
8 Replies 8
skumar1969
service app1
string cookieapp1
active
service app2
ip address 192.168.1.12
string cookieapp1
active
service app1-out
active
service app2-out
active
group servers
add service app1-out
add service app2-out
active
The above config pretty simple and straightforward not using the ACL. It would permit all the outgoing traffic intiated by the servers and will have the src ip as 192.168.1.4.
If you are using VRRP config at the client side add this ip address under the Virtual-Router as ip redundant-vip xx 192.168.1.4 on both pri and backup CSS.
thanks
Gilles Dufour
where is your content rule ?
You need to configure a content rule.
owner MyCompany
content APP
vip add 192.168.1.4
add service app1
add service app2
active
The group config is to nat traffic initiated by the server or to nat the client ip when traffic hits a content rule.
If your CSS is in a one-armed mode [that is the server can bypass the CSS to talk to the client], you will need the gorup you have configured with 'add destination service ...'.
If your application is udp based, you need a group with 'add service ...' [remove the keyword destination] in order to nat the udp response from server to client.
Gilles.
Well, I tried these, and the app1-out solution doesn't seem to work at all.
To be clearer about what I am trying to do, as I said, I am trying to get from an internal client at 10.x.y.z to APP at 192.168.1.4.
APP is the VIP on the CSS, and should be hiding 192.168.1.10 and 11 "behind" it.
This is a one-arm configurations, so my understanding
is that when the request comes in to the CSS, some part of the config should translate the destination address from 192.168.1.4 to one of the actual server addresses, and the source address to itself (192.168.1.4? or should it be the address of the VLAN?) so the server's reply goes back to the CSS.
When it gets back to the CSS, the destination address should be translated back to the real client's address (10.x.y.z), and the source address to 192.168.1.4, so the client thinks it is talking to APP, and not one of the actual servers.
Does this make sense? Is this possible? I included most of the current config (which doesn't work) in case I am missing something, or something else is wrong.
Thanks again for your help.
!************************** CIRCUIT **************************
circuit VLAN1
redundancy
ip address 192.168.1.21 255.255.255.0
no redirects
service app1
string cookieapp1
active
service app1-out
active
service app2
string cookieapp2
active
service app2-out
active
!*************************** OWNER ***************************
owner myapp
content webapp
arrowpoint-cookie expiration 00:03:00:00
balance aca
protocol tcp
port 80
url "/*"
advanced-balance sticky-srcip-dstport
add service app1
add service app2
active
group servers
active
My apologies Shathaway.
The config I gave previously suits good for a 'Routed Config' on the CSS where you got more than one interface on the CSS to connect the client side as well as the real servers. I was ignorant of the fact that you had a single-armed topology. I given a modified version of the config below.
I modified the config to include "add destination service" under the source group. Many of us think that source-group is only meant for outgoing traffic. Its half true because this command is also used for incoming traffic in a single-armed environment.
The trick here is that on the incoming traffic destined to the VIPs, CSS then spoofs the client ip address by re-writing only the destination ip address/port (aka. destination NAT-ing) leaving the src ip address untouched when it talks to the servers on its behind. In otherworlds CSS uses client ip address as the source ip address on the packets it is pumping to the servers behind. This is admissible in a 'Routing topology' since the traffic is going to be on 2 different interfaces/VLAN and the client won't know/care that CSS is actually spoofing its ip address when it talks to the servers. It hurts when it comes to single-armed config for reasons briefed below. So, when it comes to single-armed, you must not only NAT the destination address of the packet but the source addresses as well.
Assuming a situation wherein you haven't used this command in a single-armed config, the response/reply-traffic would have simply passed through the L2 switch reach the router gateway and finally on to the clients because the servers are pointing their default-gateway to the router. Now the client will actually be surprised to see the packets hitting them because it never initiated one. We know that the culprit here is the CSS who spoofed their IP address. We do not want this to happen. We need to force it to go through the CSS otherwise concept of load balancing would be lost here as you successfully bypassed the CSS from the picture. When an incoming traffic is meant for a service, NAT the source IP address to show that it is coming from the CSS. This way, the reply-traffic goes back to the CSS through the switch instead of bypassing it.
Make sure that each of your server is configured with the default-gateway being the IP address of the upstream gateway router and NOT the circuit VLAN1 of CSS which is 192.168.1.21 in your case. This is done because if you have server initiated traffic, the server initiated traffic does not have to go through the CSS and goes through the gateway router.
circuit VLAN1
redundancy
no redirects
service app1
string cookieapp1
active
service app1-out
active
service app2
string cookieapp2
active
service app2-out
active
owner myapp
content webapp
balance aca
protocol tcp
port 80
url "/*"
add service app1
add service app2
active
group servers
add destination service app1-out
add destination service app2-out
active
If you do NOT want the server-initiated-traffic to go straight and need it through the CSS so that you can stop the server communication with the clients, we got an option to do this. Try the following config, can't gurantee if this will work. I have given the source group config alone.
You need to have additional VIP for the outgoing traffic as there is a limitation that CSS permits you to assign the same VIP address to multiple source groups, but only one of the source groups can be active at any point of time.
Make sure that each of your server is configured with the default-gateway being the IP address of the circuit VLAN1 of CSS which is 192.168.1.21 in your case. This is done because if you have server initiated traffic, the server initiated traffic does have to go through the CSS.
group servers-in
active
group servers-out
vip address 192.168.1.5 ------>New VIP for outgoing.
active
thanks
I just referred Cisco pages. The above config group servers-out will work only when the source group is active and the same service is hit through a content rule, ACL preferred service, or sorry service, then only the source group is used to NAT (Network Address Translation) the source address.
thanks
As indicated in my previous answer, if you have one-armed and need client-nat you need 'add service DESTINATION '.
Inside the group, the vip can be any ip address not being used in your network currently or a vip address used by this CSS.[not the circuit vlan ip address].
This must work or you have a different issue.
If your server is using redirect, it may redirect the traffic to its own ip.
Another possibility is absolute url like http://192.168.1.10/.../... contain in some of your webpages.
Capture a sniffer trace on the client to see when it switches to a real.
Gilles.
Gilles,
the config I porposed do you thing it would work. I came out with 2 different source groups. Theoratically it is okay to me but need to get an expert's evaluation like you....just out of curiosity...
thanks
