Need config help with SSL termination on ACE
dclee
Need a bit of config help terminating SSL on the front end of the ACE..
Essentially I need all inbound (443) ssl to terminate on outside ACE IP 192.168.10.1
then have the backend connection unencrypted to backend server 172.31.17.10 on port 4400.
Any help with the class and policy maps would be appreciated.
Cheers
cpomeroy
Here is the configuration you would use for this.  Notice SSL-PROXY client on the policy map, and the ssl-proxy server on the class-map.  By adding port 4400 on the serverfarm, you can do port translation.
rserver host server
  ip address 172.31.17.10
  inservice
serverfarm host server
  rserver server 4400
    inservice
ssl-proxy service test
  key RSAKEY
  cert RSACERT
class-map match-all test
  2 match virtual-address 192.168.10.1 255.255.255.0 tcp eq https
policy-map type loadbalance first-match test
  class class-default
    serverfarm server
    ssl-proxy client test
policy-map multi-match vip
  class test
    loadbalance vip inservice
    loadbalance policy test
    loadbalance vip icmp-reply active
    ssl-proxy server test
cpomeroy
rserver host server
  inservice
  rserver server 4400
    inservice
  key RSAKEY
  cert RSACERT
  class class-default
    serverfarm server
  class test
Thanks Chris. So for every real server I need a corresponding serverfarm entry with a virtual server ?
EX..I have 2 backend servers one that responds on port 4400 and one that responds on port 5500
Would this be the correct config ?
rserver host server
inservice
rserver server 4400
inservice
rserver host server1
ip address 172.31.17.11
inservice
serverfarm host server1
rserver server1 5500
inservice
Also how do I match on URL strings and forward it to the appropriate backend web servers ? This is how I am doing it on our older CSS's
content decrypt_WEB TEST
    vip address 204.a.b.c
    add service WEB TEST
    protocol tcp
    port 8080
    url "//test.one.ca/*"
There is a converstion too on the ACE that you can use to convert your CSS configuration to ace.  Simply goto http://xx.xx.xx.xx/bin/index.  Where xx.xx.xx.xx is your ace's management ip address.
In regards to the server farm you would put both real servers under the same serverfarm.    You should not create a seperate serverfarm
Such as:
rserver server 4400
inservice
rserver server1 4400
inservice
To do the L7 url matching you would do
class-map type http loadbalance match-all url
  2 match http url /test.one.ca/.*
   class url
   serverfarm FARM1
   class  class-default
    serverfarm FARM2
This would send requests matching /test.one.ca/.* to farm 1 and everything else to farm2.
