Need help to enable WAAS
Peter Kim
I have two site with connected through GRE Tunnel.  One end is ASR1000 and the other end is 7609.  And, I have WAE674 on each ends.  I also have a WAE as central manager to manage two WAEs.  I'm trying to figure out how to setup routers.
Can I put "ip wccp 61 redirect in" and "ip wccp 61 redirect out" under Tunnel interface?  I wasn't sure if I put these commands under physical interfaces.
thanks.
ahskhan
Peter,
See below
1: on ASR and 7600 GRE tunnels, Apply
ip wccp 62 redirect out
2: Create a seprate (new) subnet for WAE on both routers and apply "ip wccp redirect exclude in" on this new interface
3: Configure WCCP globally
ip wccp 61
ip wccp 62
Best to use latest code available for ASR and WAAS. You can chose to use redirect-acl with global WCCP services if required.
You are all set for initial testing.
Ahsan
