Need help to study - Cisco ACE 4710
rahul.kukreja
Dear Members,
Request your help to please let me know the links / material which I should take to prepare Load Balancers.
I gone through some docs at knowledge base of our organisation but can't get the concept well.
Searched on google for the basics but found a bunch of documents, cannot decide from where to start and to prefer which one.
Thanks in advance..
Rahul
ddastoli
Hi Rahul,
I guess from the title you are interested in a specific load balancer study, which is 4710.
A good start would be to through the configuration guide you can find on the Cisco website:
http://www.cisco.com/en/US/products/ps7027/tsd_products_support_series_home.html
Indeed, to have a very good overview of load balancers, but also more generally on data center techs, I would suggest you to have a look at this book:
Data Center Fundamentals: Understand Data Canter network design and infrastructure architecture, including load balancing, SSL, and security (Cisco Press Fundamentals Series)
Hope this helps,
Dom.
