Need help with configure Bridged Mode on the ACE
Phi Bui Chau
Dear all!
I need to configure my new ACE appliance in bridged mode
my topology
Configure on ACE:
Context Admin
switch/Admin# show running-config
Generating configuration....
boot system image:c4710ace-t1k9-mz.A5_1_2.bin
interface gigabitEthernet 1/1
  channel-group 1
  no shutdown
interface gigabitEthernet 1/2
  channel-group 1
  no shutdown
interface gigabitEthernet 1/3
  switchport access vlan 1001
  shutdown
interface gigabitEthernet 1/4
  switchport access vlan 1000
  no shutdown
interface port-channel 1
  switchport trunk native vlan 1
  no shutdown
access-list ALL line 8 extended permit ip any any
class-map type management match-any remote_access
  2 match protocol xml-https any
  3 match protocol icmp any
  4 match protocol telnet any
  5 match protocol ssh any
  6 match protocol http any
  7 match protocol https any
  8 match protocol snmp any
policy-map type management first-match remote_mgmt_allow_policy
  class remote_access
    permit
interface vlan 1000
  ip address 10.104.10.19 255.255.255.0
  access-group input ALL
  service-policy input remote_mgmt_allow_policy
  no shutdown
ip route 0.0.0.0 0.0.0.0 10.104.10.1
context Websphere
  allocate-interface vlan 20
  allocate-interface vlan 200
username admin password 5 $1$Ei88yeEz$CT5Gy5MCkewwUT/XCV5350  role Admin domain default-domain
username www password 5 $1$a.NWKsco$sOiUlxJdrdrYbkoobfr/d1  role Admin domain default-domain
ssh key rsa 1024 force
Context Websphere
switch/Websphere# show running-config
logging enable
logging timestamp
logging trap 5
access-list everyone line 8 extended permit ip any any
access-list everyone line 16 extended permit icmp any any
rserver host was01
  ip address 10.104.20.33
  inservice
rserver host was02
  ip address 10.104.20.34
  inservice
rserver host was03
  ip address 10.104.20.35
  inservice
serverfarm host Websphere
  rserver was01
    inservice
  rserver was02
    inservice
  rserver was03
    inservice
class-map match-all slb-vip
  2 match virtual-address 10.104.20.36 any
policy-map type management first-match remote-access
  class class-default
    permit
policy-map type loadbalance http first-match slb
  class class-default
    serverfarm Websphere
policy-map multi-match client-vips
  class slb-vip
    loadbalance vip inservice
    loadbalance policy slb
interface vlan 20
  description "Client Side"
  bridge-group 1
  access-group input everyone
  service-policy input client-vips
  no shutdown
interface vlan 200
  description "Server Side"
  bridge-group 1
  service-policy input remote-access
  no shutdown
interface bvi 1
  ip address 10.104.20.30 255.255.255.0
  description "client - server bridge group"
  no shutdown
ip route 0.0.0.0 0.0.0.0 10.104.20.1
It didn't work.
i can not ping to GW, server or VIP
plz help
Kanwaljeet Singh
Your configuration looks fine. Can you also apply access group to vlan200 as well? I see you have applied remote access policy but no access group on that VLAN. Can you do that and check again.
Normally without access group on server side VLAN normal SLB should work with the above configuration.
Kanwal
