Need help with WAAS implemetation
jason.kwang
Hi All,
Have anyone try the following:
Can I implement 2 WAE (router w/SRE)  at  2 locations (data center and branch) without an dedicated WAE acting as central manager. Will this work. ? Your help is appreciate. Thanks in advance.
Jas
Jas,
This will technically work, but will not be a supported configuration.  You will also not be able to do SSL acceleration, disk encryption, schedule prepositioning, or have a central location for reporting and configuration without a Central Manager.
If physical space is a limitation in your DC you may want to look at vCM (virtual CM), which runs on VMware vSphere 4.0u1 or later.
Mike Korenbaum
Cisco Data Center PDI Help Desk
http://www.cisco.com/go/pdihelpdesk
