URL Load balance
wasiimcisco
I have CSS in single arm deployment model. I want to do the load balance following URL.
http://irs.abc.com/irs.htm
I have configure the following steps
service IRC_1
  ip address 192.168.17.12
  keepalive type tcp
  keepalive port 80
  active
service IRC_2
  ip address 192.168.17.14
  keepalive type tcp
  keepalive port 80
service IRC_DR
  ip address 192.168.10.37
  keepalive type tcp
  keepalive port 80
group TEST_IRC
  add destination service IRC_1
  add destination service IRC_2
  add destination service IRC_DR
  vip address 192.168.200.58
  active
But when I m configure the content rule it is showing following error
content IR_URL
    protocol tcp
    port 80
url "http://irs.abc.com/*
%% Unsupported or invalid content rule URI
Please let me know how to do this. Also is there anything further to configure to achive the load balancing.
Thanks in advance.
5 Replies 5
pablo.nxh
Level 3
Level 3
The problem is that you don't need the http at the front of the domain, actually if this is your only content rule on port 80 for that VIP you may want to keep it simple and just do "/*" that will catch every request for the VIP in question.
Your content rule should look like this:
content IR_URL
    protocol tcp
    port 80
    vip address X.X.X.X
    add service IRC_1
    add service IRC_2
    add service IRC_DR
    url "/*"
    active
If you still want it with the domain just do:
content IR_URL
    protocol tcp
    port 80
    vip address X.X.X.X
    add service IRC_1
    add service IRC_2
    add service IRC_DR
    url "//irs.abc.com/*"
    active
* Depending on your app this may require stickiness but give it a shot and if you run into load balance bouncing problems then revisit the stickiness configuration section.
__ __
Pablo
I tried but no luck. I can see the hit on the Rule but unable to open the web page.
ENOC_IRC         Active    IRC_1            49
                                            IRC_2            0
                                            IRC_DR           0
content ENOC_IRC
    add service IRC_1
    add service IRC_2
    add service IRC_DR
    advanced-balance sticky-srcip
    protocol tcp
    port 80
    url "/*"
    active
Kindly assist.
From the error attached I can see your server are listening on port 9000 so you need to do port translation on the services.
Configure port 9000 on each of your services
service IRC_1
  keepalive type tcp
  keepalive port 80
  port 9000
  active
Also make sure the services are "alive" with a show service summary.
The content rule will still listen on port 80 so you can connect using the URL http://irs.abc.com/irs.htm but the traffic will be sent to the servers using port 9000 (This is totally transparent to the client).
__ __
Pablo
I have tried with 9000 but no luck. Even the web page is coming up with error. Below is the configuration
service IRC_1
  keepalive type tcp
  keepalive port 80
  port 9000
  active
service IRC_2
  keepalive type tcp
  keepalive port 80
  port 9000
service IRC_DR
  keepalive type tcp
  keepalive port 80
  port 9000
CSS01# show service summary
Service Name                     State     Conn  Weight  Avg   State
                                                         Load  Transitions
ITSMWEB_1_HTTPS                  Alive         0      1     2            0
ITSMWEB_2_HTTPS                  Alive         0      1     2            0
ORALCE_PRD1                      Alive         3      1     2            0
ORALCE_DR1                       Down          0      1   255            0
ORALCE_PRD2                      Down          0      1   255            0
IRC_1                            Alive         0      1     2            4
IRC_2                            Suspended     0      1   255            2
IRC_DR                           Suspended     0      1   255            2
end of buffer
CSS01# show rule-summary
VIP Address     Port  Prot Url                CntRuleName    OwnerName Stat Idx
192.168.200.95  80    TCP                     TP        GIT  Act  5
192.168.200.58  80    TCP  /*                 IRC       GIT  Act  9
192.168.200.65  Any   Any                     EFAX      GIT  Act  2
192.168.205.28  8002  TCP                     ORACLE_DEV GIT  Act  6
192.168.200.106 30005 TCP                     ITSMAPP   GIT  Act  3
192.168.200.105 80    TCP                     ITSM_WEB  GIT  Act  4
192.168.210.57  80    TCP                     XPENAPP  GIT  Act  1
192.168.200.101 443   TCP                     ITSM_HTTP GIT  Act  7
I can telnet real server 192.168.17.12 on port  9000.
I have also capture the packet while access the real server with success and caputre on VIP which shows error.
from the screenshot it looks that your application once the page is loaded (and as this works fine i would say that the configured http rule is ok) will use some active component, like an applet, which in turn will perform connections, and from the error it looks that it tries to connect to port 9000, checking the vip trace this seems confirmed as:
ip.addr == 192.168.200.58 && !(tcp.port == 80)
shows the unsuccessful connection attempts to port 9000. So you will need another content rule, on the same VIP but listening on TCP port 9000. Looking at the serverside trace the connections to port 9000 do NOT seem to be using HTTP, so i would not define in the content rule a URL.
I also have the feeling that your first content rule was fine as before with the services pointing to port 80 for http traffic, I would add insteand new services with the same ip but with 9000 port to this second content rule.
Summarizing:
service IRC_1
  keepalive type tcp
  keepalive port 80
  active
service IRC_2
  keepalive type tcp
  keepalive port 80
service IRC_DR
  keepalive type tcp
  keepalive port 80
service IRC_1_9000
  keepalive type tcp
  keepalive port 9000
  port 9000
  active
service IRC_2_9000
  keepalive type tcp
  keepalive port 9000
  port 9000
service IRC_DR_9000
  keepalive type tcp
  keepalive port 9000
  port 9000
content IR_URL
    protocol tcp
    port 80
    vip address X.X.X.X
    add service IRC_1
    add service IRC_2
    add service IRC_DR
    active
content IR_9000
    protocol tcp
    port 9000
    vip address X.X.X.X
    add service IRC_1_9000
    add service IRC_2_9000
    add service IRC_DR_9000
    active
group TEST_IRC
  add destination service IRC_1_9000
  add destination service IRC_2_9000
  add destination service IRC_DR_9000
  active
Please note that this is a guess based on traces and errors but a proper design should be based on the input coming from the application team regarding the operational network requirements of this application.
Hope it helps,
Francesco
