Network analysis module
hassan_ayoub
Visitor
Dear Sir,
my question is i need to put nexus 7700 as a core layer in my solution, but it required to has NAM module. i found NAM supported only on Nexus 7k, so what is the solution if i will go to 7700 ???
vNAM might be an option for you.We use them on DC and few other locations and works great for us.You might want want to check if they fit your requirements.
***Please rate all the useful posts***
-Prabath
