Nexus 1000v license for 8 sockets
Mikhail Kalita
 I need to get Cisco Nexus 1000V for 8 sockets. But I'm confused which kind of licence I have to order. Do I need to order L-N1K-VLCPU-16= or can I order two L-N1K-VLCPU-04= or eight L-N1K-VLCPU-01=?
Jaime Valencia
This is the VoIP section of the forums, I suggest you move this to a relevant area.
java
if this helps, please rate
adawa
Level 3
Level 3
Hello, Mikhail.
It would be best to check with your Cisco rep for the best bundle and I also recommend getting additional sockets for future needs. Are you already working with any Cisco partner or vendor.
Let me know if you have additional concerns or e-mail (adawa@cisco.com) me directly. Kind regards.
Yes, I work in a partner of Cisco and I need to offer Cisco Nexus 1000V for a customer. And I have to figure out which kind of licence I have to select. The customer requested only one item a license for Nexus 1000 V for 8 sockets. I need to select between L-N1K-VLCPU-16=, two L-N1K-VLCPU-04= or eight L-N1K-VLCPU-01=. Are all of these variants avaliable?
