OTV IMPLEMENTATION BETWEEN PRIMARY DC & SECONDARY DC
drabofred
Dear colleagues ,
I have two data centres  to implement OTV using Cisco ASR1000 routers, I need  all the services/subnets that are currently in our Primary DC to be accessed/ replicated to the Secondary DC and Visa versa.
It's my first project and have never implemented this before so i need help on the design and configuration template for such a scenario   thanks so much
Sergiu.Daniluk
Hi @drabofred
There is a configuration example here: https://www.cisco.com/c/en/us/support/docs/routers/asr-1000-series-aggregation-services-routers/117158-configure-otv-00.html
However, I would strongly encourage you to look for a more modern alternative to OTV as a DCI technology. More specifically to VXLAN.
OTV is great, don't get me wrong, but it has lots of limitations, and is quite old. VXLAN on the other hand is a much better choise.
Good luck,
Sergiu
Thanks so much for your feedback.
What requirements do I need to have in place if I am to implement VXLAN
,the two DC are 80km apart.
can you you share any guide for VXLAN implementation thanks
balaji.bandi
