Ping across networks on same interface
Don Brack
Community Member
I'm having a issue where I cannot ping across networks configured on the same interface....If you look at the ping request I was able to ping device. 10.201.235.50. When I use the ping cmd I try and ping the same address on a differnet VLAN and the fails....Am I missing a cmd to allow icmp acrow networks?
Thanks for any assistance....
access-list ALL line 8 extended permit ip any any
access-list inbound line 8 extended permit ip any any
access-list inbound line 16 extended permit icmp any any
access-list outbound line 8 extended permit icmp any any
class-map type management match-any remote-mgmt
  201 match protocol snmp any
  202 match protocol ssh any
  203 match protocol icmp any
  204 match protocol http any
  205 match protocol https any
  206 match protocol xml-https any
interface vlan 1232
  description 10.201.232.x
  ip address 10.201.232.10 255.255.255.0
  no normalization
  mac-sticky enable
  no icmp-guard
  access-group input inbound
  nat-pool 1 10.201.232.245 10.201.232.250 netmask 255.255.255.0 pat
  service-policy input remote-mgmt
  no shutdown
interface vlan 1233
  description 10.201.233.x
  ip address 10.201.233.10 255.255.255.0
  no normalization
  mac-sticky enable
  no icmp-guard
  nat-pool 1 10.201.233.245 10.201.233.250 netmask 255.255.255.0 pat
  no shutdown
interface vlan 1234
  description 10.201.234.x
  ip address 10.201.234.10 255.255.255.0
  no normalization
  mac-sticky enable
  no icmp-guard
  nat-pool 1 10.201.234.245 10.201.234.250 netmask 255.255.255.0 pat
  no shutdown
interface vlan 1235
  description 10.201.235.x
  ip address 10.201.235.10 255.255.255.0
  no normalization
  mac-sticky enable
  no icmp-guard
  nat-pool 1 10.201.235.245 10.201.235.250 netmask 255.255.255.0 pat
  no shutdown
cacamc/Apps# ping 10.201.235.50
Pinging 10.201.235.50 with timeout = 2, count = 5, size = 100 ....
Response from 10.201.235.50 :  seq 1 time 1.042 ms
Response from 10.201.235.50 :  seq 2 time 1.288 ms
Response from 10.201.235.50 :  seq 3 time 0.290 ms
Response from 10.201.235.50 :  seq 4 time 0.334 ms
Response from 10.201.235.50 :  seq 5 time 0.279 ms
5 packet sent, 5 responses received, 0% packet loss
cacamc/Apps# ping
Target IP address:  10.201.235.50
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]:  y
Source address or interface:  10.201.235.10
Time To Live [128]:
Set DF bit in IP header [n]:
Response from 10.201.235.50 :  seq 1 time 0.000 ms
Response from 10.201.235.50 :  seq 2 time 0.000 ms
Response from 10.201.235.50 :  seq 3 time 1.307 ms
Response from 10.201.235.50 :  seq 4 time 0.000 ms
Response from 10.201.235.50 :  seq 5 time 0.320 ms
cacamc/Apps# ping
Repeat count [5]:
Source address or interface:  10.201.232.10
Time To Live [128]:
No response received from 10.201.235.50 within last 2 sec
5 packet sent, 0 responses received, 100% packet loss
cacamc/Apps#
5 Replies 5
Jorge Bejarano
Level 10
Level 10
Don,
You may want to read this.
https://supportforums.cisco.com/thread/133615
Jorge
I tried this and still no response..
access-list icmp_traffic line 10 extended permit icmp any any
class-map match-any ICMP_traffic
  description ip inspect ICMP
  2 match access-list icmp_traffic
policy-map multi-match client-vips
class epichtoccp-443
    loadbalance vip inservice
    loadbalance policy epichtoccp-443-policy
    loadbalance vip icmp-reply active
class ICMP_traffic
    inspect icmp error access-list icmp_traffic line 10 extended permit icmp any any
class ICMP_traffic
    inspect icmp error
Cesar Roque
Level 8
Level 8
Hi Don,
This sounds like an expected behavior.  From documentation:
For security reasons, the ACE  does not allow pings from an interface on a VLAN on one side of the ACE  through the ACE to an interface on a different VLAN on the other side  of the ACE. For example, a host can ping the ACE address that is on the  IP subnet using the same VLAN as the host, but cannot ping IP addresses  configured on other VLANs on the ACE
Cesar R
ANS Team
--------------------- Cesar R ANS Team
These networks are on the same interface.
