policy-map loadbalance not always work
Fco.Javier
Hello, I have a cisco balancer and
I want that the urls (www.web.com/blog, www.web/eco and www.web/info) traffic will always go to specific server, but doesn't works.
This is my settings:
ssh maxsessions 1
access-list ANY line 8 extended permit icmp any any
access-list ANY line 16 extended permit ip any any
probe icmp PROBE_PING
  interval 30
probe tcp PROBE_TCP
  interval 30
rserver host WEB_1
  ip address 172.16.10.11
  conn-limit max 50000 min 40000
  weight 1
  inservice
rserver host WEB_1AND1
  ip address 82.165.194.101
  inservice
rserver host WEB_2
  ip address 172.16.10.10
  weight 1
  inservice
serverfarm host FARM_HTTPS
  predictor leastconns
  probe PROBE_TCP
  rserver WEB_1 443
    inservice
  rserver WEB_2 443
    inservice
serverfarm host FARM_WEB
  probe PROBE_TCP
  rserver WEB_1
    inservice
  rserver WEB_2
    inservice
serverfarm host FARM_WP
  probe PROBE_TCP
  rserver WEB_1
    inservice
parameter-map type http HTTP_PARAMETER_MAP
  no persistence-rebalance
class-map match-all FARM_HTTPS
  2 match virtual-address 178.33.0.129 tcp eq https
class-map match-all L4-WEB-IP
  2 match virtual-address 178.33.0.129 tcp eq www
class-map type management match-all PUBLIC_REMOTE
  2 match protocol ssh source-address 82.165.194.101 255.255.255.255
class-map type management match-all REMOTE_ACCESS
  2 match protocol ssh any
class-map type management match-any SECURE_HTTPS
  2 match protocol https any
  3 match protocol ssh any
class-map type http loadbalance match-all WP_BLOG
  2 match http header Host header-value "www[.]WEB[.]com"
  3 match http url /blog.*
class-map type http loadbalance match-all WP_ECO
  3 match http url /eco.*
class-map type http loadbalance match-all WP_INFO
  3 match http url /info.*
class-map match-all public_remote
policy-map type management first-match REMOTE_MGMT_ALLOW_POLICY
  class REMOTE_ACCESS
    permit
policy-map type management first-match REMOTE_PUBLIC_MGMT
  class PUBLIC_REMOTE
    permit
  class SECURE_HTTPS
    permit
policy-map type management first-match SECURE_HTTPS_POLICY
  class SECURE_HTTPS
    permit
policy-map type loadbalance http first-match FARM_HTTPS_POLICY
  class class-default
    serverfarm FARM_HTTPS
    insert-http x-forward header-value "%is"
policy-map type loadbalance http first-match WEB_L7_POLICY
  class WP_ECO
    serverfarm FARM_WP
  class WP_INFO
    serverfarm FARM_WP
  class WP_BLOG
    serverfarm FARM_WP
  class class-default
    serverfarm FARM_WEB
policy-map multi-match POLICY_HTTPS
  class FARM_HTTPS
    loadbalance vip inservice
    loadbalance policy FARM_HTTPS_POLICY
    loadbalance vip icmp-reply active
    nat dynamic 1 vlan 2222
    appl-parameter http advanced-options HTTP_PARAMETER_MAP
policy-map multi-match WEB-to-vIPs
  class L4-WEB-IP
    loadbalance policy WEB_L7_POLICY
access-group input ANY
interface vlan 1215
  ip address 178.33.0.138 255.255.255.240
  alias 178.33.0.137 255.255.255.240
  peer ip address 178.33.0.139 255.255.255.240
  service-policy input REMOTE_PUBLIC_MGMT
  service-policy input WEB-to-vIPs
  service-policy input SECURE_HTTPS_POLICY
  service-policy input POLICY_HTTPS
  no shutdown
interface vlan 2222
  ip address 172.31.255.250 255.240.0.0
  alias 172.31.255.249 255.240.0.0
  peer ip address 172.31.255.251 255.240.0.0
  nat-pool 1 172.31.255.248 172.31.255.248 netmask 255.240.0.0 pat
  service-policy input REMOTE_MGMT_ALLOW_POLICY
  no shutdown
ft track interface VLAN1215
  track-interface vlan 1215
  peer track-interface vlan 1215
  priority 50
  peer priority 5
ip route 0.0.0.0 0.0.0.0 178.33.0.142
default-domain
Any idea???
Kanwaljeet Singh
Hi Javier,
I quickly went through the configuration and it looks fine. Could you please use "web" instead of "WEB" in class map statement and see if that makes a difference. uppercase WEB is not matching lowercase web when i tried in a regex builder, so that may be the issue.
I also see that you are using a parameter map. Could you please ensure that parse length is appropriately set in case you are using it.
;Let me know how it goes.
Kanwal
Cesar Roque
Level 4
Level 4
Hi Javier,
In addition to what Kanwal recommended you, I will change the HTTP parameter to look like this:
Cesar R
ANS Team
--------------------- Cesar R ANS Team
