Port Load Balancing
Bruce Summers
Level 6
Level 6
Hey folks,
Need some help with the following:
I have a class map that load balances by IP address any port/protocol...I want to NOT load balance a specific port...I think the following will do the trick, but am not positive...if anybody has any input, please provide.
class-map match-all HQ_OCS_Front_End_to_Edge_Internal_WebConf_Policy_VIP_L4
description FE to Edge Web Conf
2 match vitual-adress <IP> any
no match port tcp eq 8057
Gilles Dufour
unfortunately that would not work.
The 'no ...' command is only used to remove a previously configured command.
What you can do is create an access-list to block traffic sent to port 8057 and use this access-list as an access-group in on your inbound vlan interface.
Gilles.
