Predictor Forward in CSM (catalyst 6509)
pbadorrey
Community Member
--begin ciscomoderator note-- The following post has been edited to remove potentially confidential information. Please refrain from posting confidential information on the site to reduce security risks to your network. -- end ciscomoderator note --
Hello:
My problem is that not can make that the Catalyst, forwarded packets come vlan client when the Cache is down. Adjunt config.6509#sh runn
Building configuration...
Current configuration : 5084 bytes
version 12.1
service timestamps debug uptime
service timestamps log uptime
hostname router
boot system slot0:c6sup22-ps-mz.121-13.E3.bin
enable secret 5 xxxxxxxxxxxxxxxxxxxxx
enable password xxxxxxxxxx
ip subnet-zero
no ip domain-lookup
ip slb mode csm
ip slb vlan 30 server
ip address 192.168.198.2 255.255.255.0
gateway 192.168.198.200
ip slb vlan 40 server
ip address X.X.0.1 255.255.255.0
ip slb vlan 20 client
ip address 10.1.1.1 255.255.255.0
ip slb probe PRUEBA icmp
address X.X.0.2
interval 5
retries 1
ip slb serverfarm CACHE
no nat server
no nat client
real X.X.0.2
inservice
probe PRUEBA
ip slb serverfarm ROUTE
no nat server
no nat client
predictor forward
ip slb vserver FROMCACHE
virtual 0.0.0.0 0.0.0.0 any
vlan 40
serverfarm ROUTE
persistent rebalance
inservice
ip slb vserver HTTP
virtual 0.0.0.0 0.0.0.0 tcp www
vlan 20
serverfarm CACHE
inservice
ip slb vserver INTERNET
vlan 20
serverfarm ROUTE
inservice
ip slb vserver RESPONSE
vlan 30
serverfarm CACHE backup ROUTE
inservice
ip slb vserver RTSP
virtual 0.0.0.0 0.0.0.0 tcp rtsp service rtsp
vlan 20
serverfarm CACHE
inservice
ip slb vserver WMT
virtual 0.0.0.0 0.0.0.0 tcp 1755
vlan 20
serverfarm CACHE
inservice
no dss interface-purge
no dss range-purge
no dss mac-purge
mls rp ip
no mls netflow
mls flow ip destination
mls flow ipx destination
redundancy
mode rpr-plus
main-cpu
auto-sync running-config
auto-sync standard
interface FastEthernet6/12
no ip address
switchport
switchport access vlan 20
interface FastEthernet6/36
no ip address
duplex full
speed 100
switchport
switchport access vlan 40
interface FastEthernet6/46
no ip address
switchport
interface FastEthernet6/47
no ip address
switchport
switchport access vlan 30
interface FastEthernet6/48
no ip address
switchport
interface Vlan1
ip address 192.1.1.1 255.255.255.0
interface Vlan20
ip address 10.1.1.2 255.255.255.0
interface Vlan30
ip address 192.168.198.10 255.255.255.0
interface Vlan40
ip address X.X.0.10 255.255.255.0
ip default-gateway 192.168.198.200
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.198.200
no ip http server
didyap
Level 11
Level 11
When the cache engine goes down, the switch should be forwarding w/o using the cache. There is a keepalive mechanism to keep track of this. The switch and the cache exchange keepalives regularly. Check if there is a problem with the keepalives.
