Preposition 4.1 in auto-discovery mode
b.sahin
I am trying to configure preposition on WAE-674s with 4.1 version. I can access the related file server sharing from a standalone with the domain-name/username and password.
On the preposition windows of the central management GUI, when I push the browse button the directory (not the files in it) is shown. However preposition fails:
The attached wireshark file shows the traffic between the file server and the waas during enabling process, as I can see, I am not MS expert, after TCP handshake the WAAS don't send any packets.
accelerator cifs preposition 1008
name "Test"
server "172.27.242.222"
root "waas/"
credentials username xxx domain yyy password 1 mencrypt{zzz}
max-cache 20
min-file-size 20
no ignore-hidden-dir
recursive
scan-type full
schedule now
no enable
modified 09:10:2008 15:19:22
HOAE1674# find-pattern match "2008-10-09 16" cifs_err.log
HOAE1674#conf t
HOAE1674(config)#accelerator cifs preposition 1008
HOAE1674(config-preposition)#enable
2008-10-09 16:00:42,245 INFO (actona.directives.DirectivesManager:116) RMI TCP Connection(13)-127.0.0.1 - CFG:DirectiveList=[{directiveHeader={description=Test, type=preposition, lastModified=Thu Oct 09 16:00:42 EEST 2008, id=1008, created=Thu Oct 09 15:50:59 EEST 2008, status=enabled}, directiveBody={content={rootPathsList=[{FSName=172.27.242.222, DirectoryName=/, FSProtocol=CIFS, Sha
reName=waas}], ignoreHiddenDirectories=false, filePattern=[], Tx=, includeSubDir
ectories=true, rootURL=}, time={weekdays=0000000, weekday=1, days=, weekdaySerial=1, schedule=0, startTime=00:00}, preposition={prepositionType=full, user=x
xx\yyy, totalSize=20.0, minFileSize=20.0 [KB], password=mencrypt{zzz=}}}}]
2008-10-09 16:00:42,278 INFO (actona.preposition.PrepositionController:361) RMI TCP Connection(13)-127.0.0.1 - Starting preposition task - id:1008 lastRootIndex:0 server:172.27.242.222 share:waas rootPath: pattern:* recursive:true minSize:20480 maxSize9223372036854775807 full:true timeFilter:Thu Jan 01 02:00:00 EET 1
970 relative:false size:20562995200 duration:0
2008-10-09 16:00:42,279 INFO (actona.util.storage.InternalStorage:138) RMI TCP Connection(13)-127.0.0.1 - CFG: creating a new file for PREPOSITION storage: preposition_task1008.tmp
2008-10-09 16:00:42,289 INFO (actona.preposition.PrepositionController:385) RMI TCP Connection(13)-127.0.0.1 - Preposition ID 1008 started on 172.27.242.222\waas\.
2008-10-09 16:00:42,297 INFO (actona.aosh_io.AoShellWrapper:137) Thread-15 - Connect failed to [ server: 172.27.242.222, port: 445 ]
2008-10-09 16:00:42,297 INFO (actona.preposition.PrepositionController:961) Thread-15 - Connection failed to /172.27.242.222:445, falling back to port 139
2008-10-09 16:00:42,298 INFO (actona.aosh_io.AoShellWrapper:137) Thread-12 - Connect failed to [ server: 172.27.242.222, port: 139 ]
2008-10-09 16:00:42,298 WARN (actona.preposition.PrepositionController:981) Thread-12 - Preposition ID 1008 failed, reason: network initialization error, retrying in 30 seconds.
Bulent,
The connection for the PP job needs to be optimized (i.e. needs to pass through a peer device running the CIFS AO).
Zach
6 Replies 6
Zach Seils
Level 7
Level 7
Bulent,
Is there another WAE in between the initiating WAE and the origin file server that the PP connection can be optimized with?
Zach
There is no other WAE between the initiating WAE (172.27.249.65) and the origin file server (172.27.242.222). However I can see the many connections in PT No Peer state on the WAE
HOAE1674#show stat connection all
D:DRE,L:LZ,T:TCP Optimization,
C:CIFS,E:EPM,G:GENERIC,H:HTTP,M:MAPI,N:NFS,V:VIDEO
ConnID Source IP:Port Dest IP:Port PeerID Accel
118 172.27.249.98:3727 172.27.242.222:445 0:16:9d:39:0:5b TDLG
Local IP:Port Remote IP:Port Peer ID ConnType
172.27.249.65:37407 172.27.242.222:139 N/A PT No Peer
172.27.249.65:46900 172.27.242.222:445 N/A PT No Peer
172.27.249.65:59091 172.27.242.222:445 N/A PT No Peer
172.27.249.65:38885 172.27.242.222:445 N/A PT No Peer
172.27.249.65:22833 172.27.242.222:445 N/A PT No Peer
172.27.249.65:53076 172.27.242.222:139 N/A PT No Peer
172.27.249.65:26479 172.27.242.222:139 N/A PT No Peer
172.27.249.65:14781 172.27.242.222:445 N/A PT No Peer
172.27.249.65:49619 172.27.242.222:139 N/A PT No Peer
172.27.249.65:45850 172.27.242.222:445 N/A PT No Peer
172.27.249.65:52480 172.27.242.222:139 N/A PT No Peer
172.27.249.65:14854 172.27.242.222:139 N/A PT No Peer
172.27.249.65:44079 172.27.242.222:445 N/A PT No Peer
172.27.249.65:39368 172.27.242.222:139 N/A PT No Peer
172.27.249.65:16611 172.27.242.222:445 N/A PT No Peer
172.27.249.65:45835 172.27.242.222:445 N/A PT No Peer
172.27.249.65:17755 172.27.242.222:139 N/A PT No Peer
172.27.249.65:44403 172.27.242.222:139 N/A PT No Peer
The WAE and file server are on different vlans of the same 6500s. The file server vlan is configured with ip wccp 62 in, however its access-list do not match the related connection.
The related config on the 6500 site:
interface Vlan311
description WAAS-Normal
ip address 172.27.249.76 255.255.255.240
ip wccp 61 group-listen
ip wccp 62 group-listen
ip pim dense-mode
standby 211 ip 172.27.249.78
standby 211 preempt
interface Vlan12
ip address 172.27.242.253 255.255.255.0
ip helper-address 172.27.242.121
ip wccp 61 redirect in
standby 12 ip 172.27.242.254
ip wccp 61 group-address 224.10.10.10 redirect-list 101
access-list 101 permit tcp 172.27.238.0 0.0.0.255 172.27.249.96 0.0.0.15
access-list 101 permit tcp 172.27.241.0 0.0.0.255 172.27.249.96 0.0.0.15
access-list 101 permit tcp 172.27.242.0 0.0.0.255 172.27.249.96 0.0.0.15
access-list 101 permit tcp 172.27.245.0 0.0.0.255 172.27.249.96 0.0.0.15
thanks
Bulent
Bulent,
Zach
Hello Zach,
You are saying that the packets generated by preposition process of the waes should be optimized by the waas devices. So it means that I should not configure preposition on the core waes (waes near to file servers). Also I should remove the "redirect exclude in" lines on the interfaces facing to the branch wae devices. Do I understand correctly?
thanks,
Bulent
CIFS PP should be configured on the devices closest to the clients. The PP connection initiated from those devices must be optimized.
As far as removing 'redirect exclude in', I would need to take a closer look at your topology, traffic flow, and configuration. If you are performing WCCP interception on a software-based platform (ISR, 7200, etc.), then it doesn't hurt to leave it on. The WAE will try to optimize connections initiated from/destined to itself regardless of the interception method used.
Zach
Thanks Zach, Seils
After preposition traffic passed through core waas devices, preposiotion worked.
