Preposition problem, browse button don`t working
Boris Bordadymov
Frequent Visitor
Frequent Visitor
I`m trying to create a preposition directive on cm device (WAVE-274-K9, Software release 4.3.1).
All the server configuration is correct, I can access this server via PC with this configurations (domain\login, password).
But when I try to Browse directories I see "Could not access cifs://x.x.x.x/".
The location is chosen as the nearest WAE to the server (WAVE-474-K9, Software release 4.3.1).
In the syslog:
cm:
%WAAS-CMS-4-700001: cdm(TP-Processor12): Sitemap request failed, ce=WAVE474, unicorn.RpcException: Unmarshaled: 9001  For details see the Tx log of WAVE474
WAVE474:
%WAAS-CMS-4-700001: ce(RpcWorker-1): Failed to invoke siteMap in CifsAO           Exception: javax.management.MBeanException: Exception thrown in operation siteMap
WAVE474 has CifsAO enabled and running.
TCP connectivity to the server via cm device is working.
What can cause this problem?
Felix Arrieta
Could you create new server admin credentials and try again ?  I had a similar case where that did the job. never had the chance to get to the root problem but I believe it has to do with the server itself.
cheers,
