probe content check using Active directory credentials
Hi.
I'm having an issue with getting a HTTP probe to do a content check on a Sharepoint 2010 front end.
I have the following probe configured:
probe http TCP-HTTP-Status-Check
  description "Test HTTP request to Portal Page"
  interval 5
  passdetect interval 30
  credentials domain01\spfarmadmin password
  request method get url /default.aspx
  expect status 200 200
But when the probe runs I get an error code 401 in the probe details:
HQ-ACE1/Sharepoint2010# sh probe TCP-HTTP-Status-Check detail
probe       : TCP-HTTP-Status-Check
type        : HTTP
state       : ACTIVE
description : "Test HTTP request to Portal Page"
   port      : 80      address     : 0.0.0.0         addr type  : -
   interval  : 5       pass intvl  : 30              pass count : 3
   fail count: 3       recv timeout: 10
   http method      : GET
   http url         : /default.aspx
   conn termination : GRACEFUL
   expect offset    : 0         , open timeout     : 10
   expect regex     : -
   send data        : -
                       --------------------- probe results --------------------
   probe association   probed-address  probes     failed     passed     health
   serverfarm  : SHAREPOINT
        real      : VIRSPW01-HQ[0]
                       10.1.192.81     50         40         10         FAILED
   Socket state        : CLOSED
   No. Passed states   : 1         No. Failed states : 2
   No. Probes skipped  : 0         Last status code  : 401
   No. Out of Sockets  : 0         No. Internal error: 0
   Last disconnect err : Received invalid status code
   Last probe time     : Tue Jul  5 16:48:28 2011
   Last fail time      : Tue Jul  5 16:40:52 2011
   Last active time    : Tue Jul  5 16:39:37 2011
     real      : VIRSPW02-HQ[0]
                       10.1.192.82     50         40         10         FAILED
   Last probe time     : Tue Jul  5 16:48:29 2011
   Last fail time      : Tue Jul  5 16:40:53 2011
   Last active time    : Tue Jul  5 16:39:38 2011
A 401 means an authorization issue with the account to use for the credentials but this seems to work fine when I do it manually.
Is there an issue with my config or the way the ACE uses an AD user (domain\user) format for the credentials?  Or something else?
Thanks.
just done some searching and the below post regarding NTLM / Basic authentication has answered my query.
https://supportforums.cisco.com/thread/2010500?tstart=0
