Probe on CSM ???
edaguet
Hello all,
I have one CSM in two 6500 switches in active-passive configuration, in CSM inline mode. ( so the L3 inter-server communications go through the CSM with predictor forward)
Here the details:
- one CSM (4.1.5) in one C6509 switch with SUP2/MSFC2 using IOS 12.1(19)EA1, which is active
- and one CSM(4.1.5) in one C6513 switch with SUP720 using IOS 12.2(18)SXD3, which is passive.
I have defined two probes: one L4 and one L7. These two probes are attached to the serverfarm. A vserver is also defined.
When i test the first server with shut the service, the active CSM remove the failed server from the serverfarm but also desactivates the real server.
When i try on the backup CSM, it works very well: the csm remove only the failed server but not desactivate the real.
Where is the problem? any ideas?
thanks
Silvere
15 Replies 15
Thanks for the update.
I was actually aware of the case as the TAC engineer came to us for an explanation :-)
G.
