Probe question on ACE
kirit_patel
I have a serverfarm with four rservers defined with port 80,8080,8009. Each rserver is defined with a probe for each individual probes like TCP_80, TCP_8080 and TCP_8009
Out of these three ports only port 80 is listening. Other ports are down
When I do show serverfarm it says probe failed. why? I know 2 ports are down but port 80 is listening
20 Replies 20
more to add
actually all these ports will be listen by a http server. so with your config i have replaced the probe type to be http
The config you attached has a class map to match the vip address with a policy map type loadbalance and have a action with server farm. how do i also get stickyness applied. within the policy -map only one action is allowed
so when a request on port 8111, it should be loadbalanced and translated to port 9111. and stickyness applied. with any other ports probing 9010, 9112 failure the server should be removed from the requests being sent.
will appreciate your comments
For sticky, just create a sticky serverfarm and reference your existing serverfarm, then change your loadbalance policy to refer to your sticky serverfarm instead of your existing serverfarm. You could try reading the manuals...
load balancing policy can have either sticky command or server farm. so with the config attached where we need a single vip listening for multiple ports and then understand when a request received for a port say 8010 translated to 9010 only and not others. the load balance policy is created for the same. how do i get also sticky group attached in the same policy without affecting the requirements
part of the config from the attachment given before
class-map match-all APP-8010
2 match virtual-address 192.168.1.100 tcp eq 8010
policy-map type loadbalance first-match APP-8010-Policy
class class-default
serverfarm SF-PORT-8010
serverfarm host SF-PORT-8010
predictor leastconns
probe TCP9111
probe TCP9010
probe TCP9112
rserver Realserver1 9010
inservice
rserver Realserver2 9010
inservice
rserver Realserver3 9010
inservice
policy-map multi-match VIPS
class APP-8010
loadbalance vip inservice
loadbalance policy APP-8010-Policy
loadbalance vip icmp-reply active
how do i also get stickyness for http cookie in
Just for an example if you want to stick you sessions based on "JSESSION" cookie then the above config will change to
probe TCP9111
probe TCP9010
probe TCP9112
inservice
inservice
inservice
sticky http-cookie JSESSIONID APP-8010-STICKY
cookie offset 53 length 10
timeout 120
replicate sticky
class class-default
sticky-serverfarm APP-8010-STICKY
class APP-8010
Syed
You can read the "Cisco Application Control Engine Module Server Load-Balancing Configuration Guide" Chapter 5 - "Configuring Stickiness" to start. There is a section there on the Overview of Stickiness, Configuration Requirements and Considerations, and a specific section on Configuring HTTP-Cookie Stickiness. Finally, there are sections on Configuring an SLB Traffic Policy for Stickiness, Displaying Sticky Configurations and Statistics, Clearing Sticky Statistics, and actual Example of a Stick Configuration.
If you have a specific question, by all means ask, but a general "how do I configure stickiness" is well answered by the manuals.
